Errors with Fast & Furious 6
gellis
#1 Post by gellis » Fri May 16, 2014 8:06 pm
just got a Bluray player and so want to get a bluray ripped....
Using a Matshita BD-MLT UJ260AF
makemkv reports the highest AACS version in drive info is 39. Apparently 1.8.10 supports 42, so that shouldn't be an issue?
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..0800024C0 to device 'SG:dev_11:0'
DEBUG: Code 0 at )KQWggflvHi5nz'.A:213130283
001003:0020 DEBUG: Code 0 at -a+uV6m"q""jp`W)Z^:121264487
001003:0020 DEBUG: Code 4 at -a+uV6m"q""jp`W)Z^:29394643
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
003341:0000 Highest AACS version is v39 , MKB saved as /home/gareth/.MakeMKV/MKB_v39_FASTFURIOUS6_G55.tgz
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at PSn%irim)&7pU[?o:213131962
001003:0020 DEBUG: Code 0 at PSn%irim)&7pU[?o:29397357
I get lots of output like that.
I'm new to the blu ray ripping, so apologise if I'm asking something simple
Re: Errors with Fast & Furious 6
#2 Post by Woodstock » Sat May 17, 2014 1:55 am
Are you sure you're running version 1.8.10? Your log has the version number information chopped off. Debug logging will contain a lot more information than regular logging.
You might also try it with version 1.8.9, because there is a bug in 1.8.10 that causes problems withe SOME Bluray disks. Older versions are kept at /download/old/
gellis
#3 Post by gellis » Sat May 17, 2014 6:43 am
Thanks for replying.
I was using 1.8.10, following your instructions I downloaded 1.8.9, however am still running into the same issues.
My setup:
HP Proliant Microserver running 14.04 Ubuntu Server. The drive is a Matshita BD-MLT UJ260AF connected via USB3.
To install I grabbed the oss and bin packages, configure, make, and installed.
The board won't let me attach a log - it's at https://dl.dropboxusercontent.com/u/197 ... KV_log.txt instead.
gellis
#4 Post by gellis » Sat May 17, 2014 7:04 am
I have made another reply, but i included a link to the log file which meant it was held for moderation.....
I've just tried the blu ray and the drive on my windows laptop, which appears to be working, it's certainly got further than it did on Linux. Have I missed anything out in the setup for linux (install dependencies listed, then configuring, making and install the oss and bin packages_?
Thanks,
Gareth
#5 Post by Woodstock » Sun May 18, 2014 5:34 pm
I cannot speak to the Linux version - it's been over a year since I tried it. I do know there are some complaints in the Linux section about certain libraries MakeMKV depends upon being removed or changed on some Linux distributions recently; You should probably read those messages and see if they apply to you.
