I have a Japanese anime BD. It's got two audio tracks. One is the real one, and the other has commentary by a couple of the voice actors. When I ripped it using MakeMKV Beta 1.4.12, MakeMKV only showed one audio track. When I played the resulting MKV file, it turned out to be the commentary track, which isn't what I wanted.
Here's what MediaInfo says about that M2TS file:
General
Complete name : E:\BDMV\STREAM\00002.m2ts
Format : BDAV
Format/Info : Blu-ray Video
File size : 7.93 GiB
Duration : 26mn 52s
Overall bit rate : 42.2 Mbps
Maximum Overall bit rate : 48.0 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Duration : 26mn 52s
Bit rate : 37.5 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.754
Stream size : 7.04 GiB (89%)
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio #1
Menu ID : 1 (0x1)
Format : PCM
Format settings, Endianness : Big
Format settings, Sign : Signed
Muxing mode : Blu-ray
Duration : 26mn 52s
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 295 MiB (4%)
Audio #2
Menu ID : 1 (0x1)
Format : PCM
Duration : 26mn 52s
This is what it said about the resulting MKV file:
General
Complete name : F:\Video\AIKA_ZERO_1\title00.mkv
Format : Matroska
File size : 6.93 GiB
Duration : 26mn 52s
Overall bit rate : 36.9 Mbps
Encoded date : UTC 2010-02-12 03:49:22
Writing application : MakeMKV v1.4.12 beta win(x64-release)
Writing library : libmakemkv v1.4.12 beta (0.7.7/0.8.1) win(x64-release)
Video
Format : AVC
Muxing mode : Container profile=Unknown@4.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 26mn 50s
Resolution : 8 bits
Colorimetry : 4:2:0
Audio
Format : PCM
Codec ID : A_PCM/INT/LIT
Duration : 26mn 52s
Title : 2/0
Language : Japanese
Menu
00:00:00.000 : en:Chapter 00
00:02:37.240 : en:Chapter 01
00:04:07.247 : en:Chapter 02
00:11:55.214 : en:Chapter 03
00:24:09.948 : en:Chapter 04
00:25:40.539 : en:Chapter 05
00:26:45.103 : en:Chapter 06
Japanese BD problems.
- Contact:
Re: Japanese BD problems.
Please enable "log debug messages" in preferences, restart the program, create MKV again and post produced log file here.
Debug log started at Tue Feb 16 03:28:42 2010 , written by MakeMKV v1.4.12 beta win(x64-release)
001005:0000 MakeMKV v1.4.12 beta win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Steven/MakeMKV_log.txt
005050:0000 Evaluation version, 26 day(s) out of 30 remaining
DISCID=2C8B5804C7D462A4F397372F0C37D9A15B3E1501
001002:0020 LIBMKV_TRACE: No CC5 in 00005
003307:0000 File 00002.mpls was added as title #0
003307:0000 File 00004.mpls was added as title #1
001002:0020 LIBMKV_TRACE: No CC5 in 00001
001002:0020 LIBMKV_TRACE: No CC5 in 00000
003307:0000 File 00003.mpls was added as title #2
003025:0000 Title #00011.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00010.m2ts was added as title #3
003307:0000 File 00009.m2ts was added as title #4
003307:0000 File 00013.m2ts was added as title #5
003025:0000 Title #00012.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00000.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005011:0000 Operation sucessfully completed
005014:0000 Saving 1 titles into directory F:/Video/AIKA_ZERO_1
005005:0000 1 titles saved
005036:0104 Copy complete. 1 titles saved.
Application exited at Tue Feb 16 03:42:15 2010
- Contact:
Thank you. I would ask you to send all *.mpls and *.clpi files from this disc to support@makemkv.com . Please compress them with archiver of your choice.
Done. (It's a 58K zip file.)
By the way, I had AnyDVD-HD enabled when I grabbed all those files. Is that a problem?
- Contact:
It souldn't be but it might. I'd appreciate if you can try again without anydvd just to be sure.Chizumatic wrote:By the way, I had AnyDVD-HD enabled when I grabbed all those files. Is that a problem?
- Contact:
Error confirmed and will be corrected in a next version. Unfortunately there is no workaround with current version.
