Lost Girl Season 3
TLE0629
Lost Girl Season 3
Post by TLE0629 » Thu May 15, 2014 11:56 pm
I am trying to make a mkv of this season but MakeMKV cannot seem to differentiate the episodes. There are three episodes on the first disc but it only shows on as one on MakeMKV. I tried three different computers and all the same. Same with other discs as well.
Any ideas?
Re: Lost Girl Season 3
Post by Woodstock » Fri May 16, 2014 2:27 am
When you play the disk in a regular player, is there a "play all episodes" option, and then a menu to select the individual episodes?
It may be that all the episodes ARE in one file, and the individual play-back is a variation on the "scenes" menu.
This is something the manufacturers can change between seasons, and can even do differently between DVD and Bluray versions.
TLE0629
Post by TLE0629 » Fri May 16, 2014 3:28 am
Woodstock,
You are correct. The menu has play all episodes and then you select the episodes. I've never run into this before. I take it there is no way around this?
ndjamena
Post by ndjamena » Fri May 16, 2014 8:20 am
MKVMerge/Split is the best option so far. DVD's are hard because even on the actual discs the episodes aren't separated into individual files, if the IFO files that define the titles don't show them as separate entities MakeMKV has no way of knowing to split them. There has been talk of Splitting by Chapter within MakeMKV but I think Mike has higher priorities. If you get the same problem on a Blu Ray, try doing a back-up, then use EAC3TO and MKVMerge to extract and remux the M2TS files directly (MKVMerge won't extract PCM from an M2TS). As far as I can tell, most TV Shows on Blu Ray store each episode in their own file, even if it all shows as one title in MakeMKV.
TLE0629
Post by TLE0629 » Fri May 16, 2014 3:16 pm
Thanks, I'll try that.
