Kebast
Post
by Kebast » Wed May 07, 2014 7:45 pm
When trying to run MakeMKV 1.8.10 on Ubuntu 14.04 I get the following error:
/usr/bin$ ./makemkv
/usr/bin/makemkvcon: error while loading shared libraries: libavcodec.so.53: cannot open shared object file: No such file or directory
Has anyone worked around this? I tried building with the latest version of ffmpeg, but nothing changed.
Biqueto
Post
by Biqueto » Thu May 08, 2014 3:16 pm
Yes. Same error with my makemkv perfectly working until I've upgraded my linux to the 14.04 version this morning.
kevmitch
Post
by kevmitch » Fri May 09, 2014 1:29 am
You will definitely need to recompile makemkv against all your new librairies if you upgrade your distribution. Fortunatley, that should be all that's required.
Kebast
Post
by Kebast » Fri May 09, 2014 2:47 pm
This was a new install of 14.04. I did compile 1.8.10 with the most current version of ffmpeg as detailed
Here
Is there a way to force makemkv to use the new libavcodec 54?
Kebast
Post
by Kebast » Fri May 09, 2014 2:50 pm
Oops, guess any post with a link has to be approved.
Was a new install of 14.04, built makemkv as normal using the most current version of ffmpeg.
Any way force makemkv to use the newest libavcodec 54.
Chewi
Post
by Chewi » Sun May 11, 2014 2:14 pm
kevmitch is right. I'm not a Ubuntu user but only the open source parts link against libavcodec and it won't be tied to a specific version. It wouldn't mention libavcodec.so.53 if it hadn't picked it up somewhere while building. Search your system for any instances of it.
Kebast
Post
by Kebast » Sun May 11, 2014 3:37 pm
Well, like I said, it's a brand new install, and version 53 isn't even available for Ubuntu 14.04. Guess I'll try again, but not sure where to go from here.
Kebast
Post
by Kebast » Sun May 11, 2014 4:05 pm
I built again WITHOUT using the latest version of ffmpeg and now it works. There was also a system update today to many of the libav packages. Guess one of those two changes fixed the problem
sirrab
Post
by sirrab » Wed May 14, 2014 11:02 pm
Is there an easy way to make Ubuntu 14.04 and makemkv work together? I have tried recompiling it, to no avail. Thanks!
ZekeRage
Post
by ZekeRage » Mon May 19, 2014 7:34 pm
Kebast wrote:I built again WITHOUT using the latest version of ffmpeg and now it works. There was also a system update today to many of the libav packages. Guess one of those two changes fixed the problem
Kebast, I'm having the exact same issue here. Could you clarify what you mean by compiling without using ffmpeg? Thanks!
ZekeRage
Post
by ZekeRage » Mon May 19, 2014 7:59 pm
Nevermind, I was able to compile. Turns out I had to redownload the oss and bin files. Apparently, copying them over from another drive is a no no.
