Language of audio tracks are not recognized with XBMC
Melanie
Post by Melanie »
Language of audio tracks produced with makeMKV are not recognized with XBMC
i produced a mkv file with makemkv from a DVD. Playing the mkv with mediaplayer classics and VLC shows the language of the audio track.
XBMC does not.
Producing the MKV with mkvmerge from the MKVToolnix: XBMC, VLC and media player classics are able to show the language of the audio track.
Producing the MKV with handbrake: all (XBMC, VLC and media player classics) are able to show the language of the audio track.
MediaInfo:
makemkv:
Audio #1
Mode extension                           : CM (complete main)
Format settings, Endianness              : Big
Codec ID                                 : A_AC3
Duration                                 : 1h 31mn
Bit rate                                 : 448 Kbps
Channel positions                        : Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 KHz
Bit depth                                : 16 bits
Stream size                              : 292 MiB (8%)
Language                                 : German
mkvmerge from toolnix (identically to handbrake):
Audio #1
Codec ID                                 : A_AC3
Duration                                 : 1h 31mn
Bit rate                                 : 448 Kbps
Bit depth                                : 16 bits
Language                                 : German
The difference is
Title : Surround 5.1
Is this is a misinterpreting from XBMC or a wrong produced outputfile from makeMKV? Does anyone have some experiences with the specification?
Romansh
Re: Language of audio tracks are not recognized with XBMC
Post by Romansh »
If you set the track title in mkvmerge (or mkvmerge GUI), can XBMC still show the audio track language?
Melanie
Post by Melanie »
Romansh wrote:If you set the track title in mkvmerge (or mkvmerge GUI), can XBMC still show the audio track language?
Good idea!
The answer is: After setting the the track itle in mkvmerge GUI, XBMC does no show the track language any more.
Thank you, i will have a look at the XBMC forum
Melanie
Post by Melanie »
FYI:
forum post and ticket @xbmc
MKV: language of audio track is not recognized, if a title is set
http://forum.xbmc.org/showthread.php?tid=194965
#15237 (MKV: language of audio track is not recognized, if a title for this audio track set) – XBMC
http://trac.xbmc.org/ticket/15237
