Failed to open disc - Version 1.8.10 - Help???
icemantx
#1 Post by icemantx » Sat May 10, 2014 6:00 pm
I installed Make MKV today and I am having trouble ripping a Blu-Ray of our wedding using Mac OS X 10.9.2. I have successfully backed up other blu-ray discs, but not one made by a videographer. When I try to load the disc I see the following message:
MakeMKV v1.8.10 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/jeffcurtis/MakeMKV_log.txt
Optical drive "BD-ROM HL-DT-ST BDDVDRW CT30F YT04d" opened in OS access mode.
DEBUG: Code 0 at `[V!yyzF[,R\EW+F:213139874
DEBUG: Code 0 at `[V!yyzF[,R\EW+F:213131962
DEBUG: Code 0 at `[V!yyzF[,R\EW+F:29397357
Then I just went ahead and tried to backup the disc and received this (decryption removal not checked):
Backing up disc into folder "/Users/jeffcurtis/Movies/backup/BDROM"
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:7f43bdde48a7c08f:HL-DT-ST BDDVDRW CT30F YT04'
DEBUG: Code 0 at 9RA)|D47'P}hUs,WUW:121264487
DEBUG: Code 0 at 9RA)|D47'P}hUs,WUW:29394643
DEBUG: Code 1 at 9RA)|D47'P}hUs,WUW:29394643
DEBUG: Code 2 at 9RA)|D47'P}hUs,WUW:29394643
DEBUG: Code 3 at 9RA)|D47'P}hUs,WUW:29394643
DEBUG: Code 4 at 9RA)|D47'P}hUs,WUW:29394643
DEBUG: Code 0 at q%Ycvs(qOO3|X#j:29394114
Content hash table missing, unable to verify integrity of M2TS files.
The back up of the disc is made to my iMac but I cannot use it since it just copies the blu-ray files over as they are and does not make any files I can use. Since I MakeMKV displays the failed to open disc message, I never get the option to create an MKV.
Any ideas?
ndjamena
Re: Failed to open disc - Version 1.8.10 - Help???
#2 Post by ndjamena » Sat May 10, 2014 9:31 pm
Is it copy protected? You could try using MKVMerge on the .mpls or m2ts files directly. I doubt there would be anything on the disc that would complicate things.
kevmitch
#3 Post by kevmitch » Sat May 10, 2014 9:33 pm
If you have already tried carefully cleaning the disc, you might want to try an old version (1.8.7) of MakeMKV as some of the more recent changes have had disruptive consequences on some discs.
#4 Post by Woodstock » Sat May 10, 2014 10:44 pm
Mike has said there is a bug that is triggered by a disk NOT having certain directories that "all" commercial disks have. Going back to an older version works around that bug.
icemantx
#5 Post by icemantx » Sat May 10, 2014 11:08 pm
Just installed 1.8.7 and still stuck...
MakeMKV v1.8.7 darwin(x86-release) started
The new version 1.8.10 is available for download at http://www.makemkv.com/download
DEBUG: Code 0 at :[9;9:.$A22nlc0U:29402877
DEBUG: Code 0 at :[9;9:.$A22nlc0U:29395379
DEBUG: Code 0 at :[9;9:.$A22nlc0U:29396943
OS device name: /dev/rdisk3
Product: BDDVDRW CT30F
Revision: YT04
Serial number: M00AA7B4823
Firmware date: 2009-07-17 16:20:
Highest AACS version: 33
Disc Information
Data capacity: 22.5 Gb
Disc type: BD-RE
Number of layers: 1
Any other ideas?
