The Legend Of Hercules 3D
spl147
#1 Post by spl147 » Sun May 04, 2014 1:27 pm
anyone know the correct playlist of the US retail disc?
jeolson
Re: The Legend Of Hercules 3D
#2 Post by jeolson » Tue May 06, 2014 8:25 pm
Have you figured this out yet I need the same thing
jrwalker4
#3 Post by jrwalker4 » Thu May 08, 2014 12:14 pm
spl147 wrote: anyone know the correct playlist of the US retail disc?
I have the 0-25192-23259-6 Combo 2D/3D copy from Amazon. When I manually rebuilt the playlist for my disc the playlist was 783 for the 2D version and 847 for the paired 3D playlist version.
00783.mpls: Segment map:
506,511,503,515,508,514,507,504,512,509,502,513,505,501,510
00847.mpls: Segment map: 506/601,511/602,503/603,515/604,508/605,514/606,507/607,504/608,512/609,509/610,502/611,513/612,505/613,501/614,510/615
dealio
#4 Post by dealio » Mon Aug 09, 2021 3:34 pm
Thanks for doing all that work jrwalker4! It's great to be able to use your work.
I've never seen slashes in a playlist segment map; not sure what that means. Does the actual 00847.mpls playlist have 15 segments: 601, 602, 603, 604, 605, 606, 607, 608, 609, 610, 611, 612, 613, 614, 615? Wonder how many minutes the resulting movie is? Helps to verify that I've got a correct playlist.
dealio
#5 Post by dealio » Mon Aug 09, 2021 5:08 pm
I just loaded the disc in MakeMKV. I see the segment map as you've described it with slashes. No need to respond.
Thanks.
Krawk
#6 Post by Krawk » Tue Mar 04, 2025 6:03 pm
Just now inserted this disc to rip to my hard drive.
Was wondering why makemkv did not auto-populate this one. I assume there is no Java code on the disc to process?
Nice work on reconstruction of the playlist!
