LOST Season 5 and 6 DVDs not decoding
Dan_C
#1 Post by Dan_C » Sun May 04, 2014 8:07 pm
Hi Guys,
As per FAQ on this subject here are the .IFO files and the debug file as well as a gif of the DVD directory. There are only 4 episodes on the disc. If you Need any more Infos let me know.
Thanks, you guys are really doing a great job.
Regards,
Dan
Re: LOST Season 5 and 6 DVDs not decoding
#2 Post by Woodstock » Mon May 05, 2014 2:41 am
Since none of your files were visible to us normal users, what version of MakeMKV were you trying this with?
Dan_C
#3 Post by Dan_C » Mon May 05, 2014 4:08 pm
Hi Woodstock,
I am using Version v1.8.10 (winx64 release).
I also tried 3 different drives: 2 Samsung SE-208DB DVD and an LG BE14NU40 BD drive.
Interestingly, I can rip season 6 discs (actually I am just ripping disc one now). Initially as MKV was scanning the disc the same errors were issued as with the season 5 discs... but its ripping! Now on disc 2.
MakeMKV v1.8.10 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Dan_Big/MakeMKV_log.txt
DEBUG: Code 117506160 at KyeLi|>Qf`[),~v,.;:213132100
DEBUG: Code 117506160 at KyeLi|>Qf`[),~v,.;:29393930
Error 'Internal error - Operation was cancelled (112)' occurred while reading 'BD-RE HL-DT-ST BD-RE BE14NU40 1.00' at offset '827392'
LIBMKV_TRACE: UDF mount: disc not properly formatted or damaged disc (rootdirs failing)
Error 'Internal error - Operation was cancelled (112)' occurred while reading 'BD-RE HL-DT-ST BD-RE BE14NU40 1.00' at offset '32768'
DEBUG: Code 0 at |gq="y.-${&t@ZG^`}R:213129777
Calculated BUP offset for VTS #0 does not match one in IFO header.
Calculated BUP offset for VTS #1 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Calculated BUP offset for VTS #4 does not match one in IFO header.
Calculated BUP offset for VTS #5 does not match one in IFO header.
Calculated BUP offset for VTS #6 does not match one in IFO header.
Calculated BUP offset for VTS #7 does not match one in IFO header.
Calculated BUP offset for VTS #8 does not match one in IFO header.
Calculated BUP offset for VTS #9 does not match one in IFO header.
Calculated BUP offset for VTS #10 does not match one in IFO header.
Calculated BUP offset for VTS #11 does not match one in IFO header.
Calculated BUP offset for VTS #12 does not match one in IFO header.
Calculated BUP offset for VTS #13 does not match one in IFO header.
Calculated BUP offset for VTS #14 does not match one in IFO header.
Calculated BUP offset for VTS #15 does not match one in IFO header.
Calculated BUP offset for VTS #16 does not match one in IFO header.
Calculated BUP offset for VTS #17 does not match one in IFO header.
Calculated BUP offset for VTS #18 does not match one in IFO header.
Calculated BUP offset for VTS #19 does not match one in IFO header.
Calculated BUP offset for VTS #20 does not match one in IFO header.
Calculated BUP offset for VTS #21 does not match one in IFO header.
Calculated BUP offset for VTS #22 does not match one in IFO header.
Calculated BUP offset for VTS #36 does not match one in IFO header.
Calculated BUP offset for VTS #37 does not match one in IFO header.
Calculated BUP offset for VTS #38 does not match one in IFO header.
Can't locate a cell for VTS 2 TTN 1 PGCN 1 PGN 0
Can't locate a cell for VTS 3 TTN 1 PGCN 1 PGN 0
Can't locate a cell for VTS 4 TTN 1 PGCN 1 PGN 0
Can't locate a cell for VTS 5 TTN 1 PGCN 1 PGN 0
Can't locate a cell for VTS 6 TTN 1 PGCN 1 PGN 0
Can't locate a cell for VTS 7 TTN 1 PGCN 1 PGN 0
Can't locate a cell for VTS 8 TTN 1 PGCN 1 PGN 0
DEBUG: Code 0 at Qy|3!I=!(V77*if!:213142312
DEBUG: Code 0 at 6s@-P8SJ/&{pdqfV}B:213130996
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-6 were removed from title start
Cells 15-15 were removed from title end
Title #11 declared length is 0:41:15 while its real length is 0:21:36 - assuming fake title
Title #12 declared length is 0:41:15 while its real length is 0:21:36 - assuming fake title
Title #15 declared length is 0:41:15 while its real length is 0:21:36 - assuming fake title
Title #18 declared length is 0:41:15 while its real length is 0:21:36 - assuming fake title
Title #19 declared length is 0:41:15 while its real length is 0:21:36 - assuming fake title
Title #20 declared length is 0:41:15 while its real length is 0:21:36 - assuming fake title
Title #22 was added (8 cell(s), 0:41:15)
Title #24 declared length is 0:41:15 while its real length is 0:21:36 - assuming fake title
Title #25 declared length is 0:41:15 while its real length is 0:21:36 - assuming fake title
Title #27 declared length is 0:41:15 while its real length is 0:21:36 - assuming fake title
Cells 16-16 were removed from title end
Title #36 was added (9 cell(s), 0:40:08)
Title #42 declared length is 0:40:08 while its real length is 0:18:39 - assuming fake title
Title #47 was added (9 cell(s), 0:41:08)
Title #54 declared length is 0:41:08 while its real length is 0:18:40 - assuming fake title
Title #56 declared length is 0:41:13 while its real length is 0:18:51 - assuming fake title
Title #57 declared length is 0:41:13 while its real length is 0:18:51 - assuming fake title
Title #58 declared length is 0:41:13 while its real length is 0:18:51 - assuming fake title
Title #59 declared length is 0:41:13 while its real length is 0:18:51 - assuming fake title
Title #61 declared length is 0:41:13 while its real length is 0:18:51 - assuming fake title
Title #64 declared length is 0:41:13 while its real length is 0:18:51 - assuming fake title
Title #65 was added (9 cell(s), 0:41:13)
Title #66 declared length is 0:41:13 while its real length is 0:18:51 - assuming fake title
Title #71 has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #72 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #72/2 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #72/3 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #72/4 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #72/5 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #72/6 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #72/7 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #72/8 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #72/9 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #72/10 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #73 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #77/3 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #77/4 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #77/5 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #77/6 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #77/7 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #77/8 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #77/9 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #77/10 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #78 has length of 100 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 4-end were skipped due to cell commands (structure protection?)
Title #80 was added (3 cell(s), 0:03:31)
Cells 2-end were skipped due to cell commands (structure protection?)
Title #88 was added (1 cell(s), 0:08:06)
Title #95 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #95/1 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #95/2 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #95/3 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #95/4 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #95/5 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #95/6 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #95/7 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #95/8 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #95/9 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #96 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Can't locate a cell for VTS 36 TTN 1 PGCN 1 PGN 0
Can't locate a cell for VTS 37 TTN 1 PGCN 1 PGN 0
Can't locate a cell for VTS 38 TTN 1 PGCN 1 PGN 0
Saving 4 titles into directory Z:/Video/TV_Series/Lost/S6/D1
4 titles saved
Sorry about the post length, I couldn't find out how to create a scrolling Quote-box. Some help there anyone?
BR,
Dan
#4 Post by Woodstock » Mon May 05, 2014 11:19 pm
I don't think Mike has installed the mod that does the scrolling code/quote boxes; this is a pretty stock version of phpBB.
Mike will have to translate what the specific debug messages mean. They tell what work-arounds MakeMKV tried in an effort to get valid data.
One suggestion would be to try an older version of MakeMKV. There have been some bugs in the last few versions that break different things, and 1.8.10 has problems with a few DVDs. I have 3 different versions installed - 1.8.7, 1.8.9, and 1.8.10 - to cover all the bases on BD and DVD. You can have more than one version installed, so long as they're in different directories.
/download/old/
