Star Wars Clone Wars Season 5 BD error
AMGC63
#1 Post by AMGC63 » Sun May 04, 2014 8:36 pm
Hi
I have been trying to rip the season 5 of Clone Wars but unfortunately makemkv is unable to do so and the following shows. Can anything be done about this issue?
MakeMKV v1.8.10 darwin(x86-release) started
Optical drive "DVD+R-DL PIONEER DVD-RW DVR-112D BC14d" opened in OS access mode.
Optical drive "BD-RE TSSTcorp BDDVDW SE-506BB TS00d" opened in OS access mode.
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:4807841c7f668195:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..08C55882240E1AE8F5ED0691672EAA209E8 to device 'IoKit:IOBDServices:4807841c7f668195:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..02B20A92A9DEE40D9BCE9F6AE3708D92B39 to device 'IoKit:IOBDServices:4807841c7f668195:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0B2A7C454F9CB2F46A313D34C7BA434DEDB to device 'IoKit:IOBDServices:4807841c7f668195:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..066A24D93E8B5FB3DF1AC7D468CCB260B7C to device 'IoKit:IOBDServices:4807841c7f668195:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..083F48FB17FBE7CEBB4C9B1A34CBBB7159A to device 'IoKit:IOBDServices:4807841c7f668195:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0E9CB44A5F0D05A03DFC0761D22838839B9 to device 'IoKit:IOBDServices:4807841c7f668195:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'IoKit:IOBDServices:4807841c7f668195:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..06B99F79308E150DE56D68847398233D3D7 to device 'IoKit:IOBDServices:4807841c7f668195:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0863605613F7C1CCAC098AAE1C5DF31D224 to device 'IoKit:IOBDServices:4807841c7f668195:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..03599B0521E8C86DFB54F74C807D8AD5A10 to device 'IoKit:IOBDServices:4807841c7f668195:TSSTcorp BDDVDW SE-506BB TS00'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0B10CF4215A42F003EDC8A432CEE388A2E5 to device 'IoKit:IOBDServices:4807841c7f668195:TSSTcorp BDDVDW SE-506BB TS00'
Highest AACS version is v42 , MKB saved as /Users/Ilir/Library/MakeMKV/MKB_v42_STAR_WARS_CLONE_WARS_S5_D1.tgz
Re: Star Wars Clone Wars Season 5 BD error
#2 Post by Woodstock » Mon May 05, 2014 2:44 am
Most likely, everything cascaded from this problem:
Some part of the disk can't be read by your drive, which then caused a problem with decoding the AACS, which caused the encryption key issue.
AMGC63
#3 Post by AMGC63 » Mon May 05, 2014 7:02 pm
Woodstock wrote: Some part of the disk can't be read by your drive, which then caused a problem with decoding the AACS, which caused the encryption key issue.
Thank you for the reply. Is this likely caused by a scratch or some dirt on the disc?
#4 Post by Woodstock » Mon May 05, 2014 11:32 pm
Those are the most common sources for these errors. A standard part of your "video tool kit" should be a soft cloth and cleaning solution.
I use Pledge furniture polish as the cleaning solution, because it cuts through most finger prints, and is also a wax that can "fill" small scratches. The cloth should be non-scratching; some people use microfiber towels, I use COTTON shop towels that are kept separate from anything that could contaminate them with oil or abrasive dirt.
But there can also be mastering errors in the disk itself - bad spots that were there in the pressing, not the fault of anything that happened afterward. Those can only be dealt with by getting the disk(s) replaced, hopefully with one from a different batch.
