Last Vegas - Copy complete. 0 titles saved, 1 failed.
dannydxd
#1 Post by dannydxd » Fri May 02, 2014 10:29 pm
The copy appears to have succeeded, but then fails. Here's the log.
Saving 1 titles into directory E:/Video
Failed to save title 2 to file E:/Video/Last_Vegas_t03.mkv
o titles saved, 1 failed.
It appears that the copy from disc succeeded, but copying it to it's final destination fails. The temporary directory and the destination directory are all on the same drive and have over 2TB free on it, so it's not a space issue. I copied another BR disc after this failure to make sure there isn't an issue of disk writes, space, etc. and that worked just fine too.
There's nothing visually wrong with the disc, no scratches, finger prints, etc.
I checked the temp directory and all i see is MKB_v43_LAST_VEGAS.tgz 15kb file, and destination directory is empty.
I only ever copy just the main title.
The BD reader is BD-RE PIONEER BD-RW BDR-208D 1.10
Re: Last Vegas - Copy complete. 0 titles saved, 1 failed.
#2 Post by Woodstock » Sat May 03, 2014 5:08 am
Please enable debug logging (information in signature below) and post that log. It will have more information.
Gene Poole
#3 Post by Gene Poole » Mon May 05, 2014 4:24 am
I get the same error. I didn't enable debugging before I returned the disc, but I did do a backup and got something along the lines of "Hash error, 99.4% OK" or some such (I didn't record the exact message). The TS files in the backup directory seemed to play fine. After seeing this post, I decided to try to make an MKV from the backup directory and it failed as above. I enabled debug logging and here is the log:
MakeMKV v1.8.10 linux(x64-release) started
Debug logging enabled, log will be saved as /root/MakeMKV_log.txt
Opening files on harddrive at /Movies/Movies/backup/LAST VEGAS
Title #00125.mpls has length of 96 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 100 at dXcoFwX~8p6]~[d!EG+J:121265039
DEBUG: Code 0 at ]ZAoxRX;}lZO$8qaLd0r:121262049
DEBUG: Code 0 at ]ZAoxRX;}lZO$8qaLd0r:213130168
DEBUG: Code 0 at ]ZAoxRX;}lZO$8qaLd0r:29393286
DEBUG: Code 0 at V>=:N;Znwa#}cRf%hJ:29393539
DEBUG: Code 0 at V>=:N;Znwa#}cRf%hJ:213130444
Failed to decode audio/video data for title #0 - invalid mux or internal error, title skipped.
DEBUG: Code 0 at ;CN{,D(r:bFzd9e(:213131525
DEBUG: Code 0 at ^eZWfQgE+-O~j?X:213138770
DEBUG: Code 0 at PSn%irim)&7pU[?o:29407385
Title #00121.mpls was skipped
Title #00024.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00126.mpls was skipped
Title #00021.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #0
Title #00120.mpls has length of 116 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00011.mpls was added as title #1
File 00010.mpls was added as title #2
Title #00123.mpls has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Failed to decode audio/video data for title #3 - invalid mux or internal error, title skipped.
Title #00124.mpls was skipped
Title #00122.mpls has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 96 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 110 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00028.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts was skipped
Title #00032.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts was skipped
Title #00020.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Movies/Movies
Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
DEBUG: Code 0 at Q?~+0_1d"(N[ >gv3X):213132744
DEBUG: Code 0 at Q?~+0_1d"(N[ >gv3X):213137367
DEBUG: Code 0 at Q?~+0_1d"(N[ >gv3X):213135021
DEBUG: Code 0 at Kwi"&"y&~menA(nfARL1S:213135090
DEBUG: Code 0 at #X>1SpDTNwG*KLM>E:213131893
DEBUG: Code 0 at #X>1SpDTNwG*KLM>E:121263406
DEBUG: Code 0 at #X>1SpDTNwG*KLM>E:29393907
Failed to save title 0 to file /Movies/Movies/Last_Vegas_t00.mkv
#4 Post by mike admin » Fri May 09, 2014 10:13 am
This is a known bug in 1.8.10 . Your only option for now is to use the previous version 1.8.9 in order to process this disc.
