Attempting to use CLI to rip from disc, no luck
Qriist
#1 Post by Qriist » Sat Feb 20, 2010 10:17 pm
I am attempting to use the CLI to rip from retail discs and I'm afraid I'm not using the proper syntax. I would like an example on how to use the CLI's disc mode with both DVD's and BD's (if there is indeed a difference between them...)
Thanks in advance!
---Qriist
ds2249
Re: Attempting to use CLI to rip from disc, no luck
#2 Post by ds2249 » Sun Feb 21, 2010 7:39 am
Qriist wrote:I am attempting to use the CLI to rip from retail discs and I'm afraid I'm not using the proper syntax. I would like an example on how to use the CLI's disc mode with both DVD's and BD's (if there is indeed a difference between them...)
Thanks in advance!
---Qriist
Please see this example :
http://www.makemkv.com/forum2/viewtopic.php?f=1&t=996
Qriist
#3 Post by Qriist » Sun Feb 21, 2010 10:31 am
While I thank you for the attempted answer, I am afraid it doesn't help. It's failing to rip from a physical disc, not files residing on my hard drive. I've successfully ripped this particular disc with the GUI so I know that decryption is possible, only apparently broken right now, from my syntax or another reason...
#4 Post by mike admin » Mon Feb 22, 2010 7:55 am
makemkvcon mkv disc:0 all c:\folder
Qriist
#5 Post by Qriist » Fri Feb 26, 2010 1:19 pm
That worked like a charm! Thanks!
