Pokemon multi-feature bluray error on 2 of 4 movies, empty..
FattyMoBookyButt
Post by FattyMoBookyButt » Thu May 01, 2014 12:06 am
Disc: Pokemon Miramax multi-feature
Includes:
Pokemon Heroes
Pokemon 4ever
Pokemon Jirachi Wish Maker
Pokemon Destiny Deoxys
Log output:
DEBUG: Code 0 at O_h|[Z2T<;A(7V><K1g:213132744
DEBUG: Code 0 at O_h|[Z2T<;A(7V><K1g:213137367
DEBUG: Code 0 at O_h|[Z2T<;A(7V><K1g:213135021
DEBUG: Code 0 at 4(yOYXRk(~=y3s-rF"jD,:213135090
DEBUG: Code 0 at Q.'fmXp (O|q=Ba-::213131893
DEBUG: Code 0 at Q.'fmXp (O|q=Ba-::121263406
DEBUG: Code 0 at Q.'fmXp (O|q=Ba-::29393907
Failed to save title 4 to file D:/Media/Outbox/Pokemon_Destiny_Deoxys_t04.mkv
I just noticed that the 2 movies that worked only referenced 1 segment each, while the 2 movies that failed both referenced 2 segments each.
One includes '4,0' and the includes '19,0'. After failing straight from the disc, I ripped it to the hard-drive (and removed encryption) and if I play the 00000.m2ts file, it's just black noise, even though it seems to have a full AC-3 audio and AVC video track according to MediaInfo. And it has a length of 2:43.
I'm copying the M2TS segments of each (00004.m2ts and 00019.m2ts) to my working directory and hopefully those will work in handbrake. (I guess I can't remux/transmux a M2TS file with MakeMKV in the same way you can do it with a MKV file?)
Just submitting this here to report an issue and in case others are trying to work with this title.
Re: Pokemon multi-feature bluray error on 2 of 4 movies, emp
Post by Woodstock » Thu May 01, 2014 12:58 am
What version of MakeMKV are you using (your log has that clipped off)?
There are some issues on SOME Bluray disks with version 1.8.10. There are issues with 1.8.9 with some DVDs. While we're waiting for Mike to release a version that fixes these issues, you sometimes have to have multiple versions installed.
/download/old/ has previous versions, if you do not have them already.
