BD tv show saving until the end of each show then failing
Carnage
Post by Carnage »
I am trying to extract under the dome so I can do a marathon before season 2 this summer.
Disc 1 and 2 no issue with previous Makemkv version. I just went to new version and having an issue.
It is working on saving the episode(s) and right as it finishes (appears to be 100%) it then fails. I can see in the folder it is saving that the file is in fact being written to, but then disapears at it reaches the end, and makemkv says it failed.
I can email all the files needed but was hoping to solve here first before having to bother support or Mike.
I do use AnyDVD and sometimes rip to ISO and mount and then makemkv after. This has failed also but in past has not.
here are the logs, was going to attach but says i quota already reached.
with anydvd running
Debug log started at Mon Apr 28 00:01:52 2014 , written by MakeMKV v1.8.10 win(x64-release)
001005:0000 MakeMKV v1.8.10 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Carnage/MakeMKV_log.txt
003335:0508 It appears that you have AnyDVD enabled. MakeMKV should process discs with most sophisticated protections without help of any 3rd party decryption software. In addition MakeMKV works faster and more reliably when it decrypts data by itself. It is highly recommended to disable AnyDVD and restart the application.
Do you want to continue anyway (errors may follow) ?
003305:0000 AACS directory not present, assuming unencrypted disc
DISCID=564E217AB29B56EA5C8C97CBE0013D45DE64985E
003025:0000 Title #00009.mpls has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00002.mpls was added as title #0
003307:0000 File 00001.mpls was added as title #1
003307:0000 File 00000.mpls was added as title #2
003025:0000 Title #00019.mpls has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00018.mpls has length of 89 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00025.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00014.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00013.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00026.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00017.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00022.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory C:/Raw
001003:0020 DEBUG: Code 0 at O_h|[Z2T<;A(7V><K1g:213132744
001003:0020 DEBUG: Code 0 at O_h|[Z2T<;A(7V><K1g:213137367
001003:0020 DEBUG: Code 0 at O_h|[Z2T<;A(7V><K1g:213135021
001003:0020 DEBUG: Code 0 at 4(yOYXRk(~=y3s-rF"jD,:213135090
001003:0020 DEBUG: Code 0 at Q.'fmXp (O|q=Ba-::213131893
001003:0020 DEBUG: Code 0 at Q.'fmXp (O|q=Ba-::121263406
001003:0020 DEBUG: Code 0 at Q.'fmXp (O|q=Ba-::29393907
005003:0000 Failed to save title 0 to file C:/Raw/Under_The_Dome_Season_1_Disc_3_t00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Mon Apr 28 00:13:57 2014
without anydvd running
Debug log started at Mon Apr 28 00:14:47 2014 , written by MakeMKV v1.8.10 win(x64-release)
DAFD=PAAAADAAAAEABDQkEGgEEAQ==
DCE=HkNGDQyDCg/Qz2DsilTsURDRfBbV6HTC/ZHzGqBWlrsQfBe2zLdocWWqgVk0i6qlPpfdoa/Cogd/KBXUntMzo7Jj0qr1bm0nPqHp1VrpRb2PXStTpUpfPBWz9xqLhlo4plWcMqfHV0szeGA3Gyp3YVun7Ud4i3e77g==
DCE=qLiLtw7IyCpYf2zmBNewIiMPp7J+vYTG0y8RwUcjNWKIHpSAp6HNn/NxAoQMgMbhAysQ2cBFYguKuGQ8AqMAwD9g+Ar4tbyMo/mdyYA32B7+4wq8h2vfVZvAHYusVLIUkqyzXD/6MdMFIkkPa8vdAL6v9k3NvgFhig==
Application exited at Mon Apr 28 00:24:56 2014
also just noticed that the time says monday but computer is set for real time and date where i am
Thanks again
Re: BD tv show saving until the end of each show then failin
Post by mike admin »
This looks like an incorrectly mastered disc for which MakeMKV failed to work around. Please do the testdumps for all titles that fail per instructions at /onlinehelp/testdump.html . When sending the email with links please briefly mention the issue and put a link to this topic in email. Thank you!
Arnold_Layne
Post by Arnold_Layne »
Seems to be a bug in 1.810. Mike hasn't responded to the Star Trek TNG posts which others are having the same issue. If you go back to 1.89 I bet the titles will save just fine.
A_L
Operating System
Windows 8.1 64-bit
CPU
Intel Core i7 4820K @ 3.70GHz
RAM
32.0GB DDR3 @ 800MHz
Motherboard
ASUS SABERTOOTH X79
Graphics
3071MB NVIDIA GeForce GTX 780
Storage
100GB SSD
5X4TB HDD
Optical Drives
HL-DT-ST BD-RE BH14NS40
Carnage
Post by Carnage »
thanks for the reminder, forgot to try 1.8.9 and it is working
Mike,
If all 3 succeed, i will save that log.txt and also do a *testdump* on the disc again with 1.8.9 and send email with info
I do not know if this will help but maybe it can help find a point where different since I am unable to compare dumps.
