How can change bitrate 8000 to other value
Adminny
#1 Post by Adminny » Fri Apr 25, 2014 12:45 pm
MakeMKV makes all mkv files with bitrate 8000.
How can change bitrate to other value?
SiliconKid
Re: How can change bitrate 8000 to other value
#2 Post by SiliconKid » Fri Apr 25, 2014 1:18 pm
MakeMKV does not re-encode anything so it cannot influence the bitrate of anything.
MakeMKV ONLY rips discs into an MKV container. The audio and video streams from the source do NOT get altered and neither do their bitrates.
It is therefore impossible for MakeMKV to affect the bitrate of anything.
Where are you seeing a bitrate of 8000 ? What does MediaInfo say about those files ? What was the source of the files you are referring too ?
