User Documentation Needs
Chetwood
Re: User Documentation Needs
#16 Post by Chetwood » Wed Apr 23, 2014 4:51 am
Walter Lacey wrote:..... tried this effort now with FreeMKV2Dvd, Handbrake, Avi2Dvd DVDStyler, FlickDVD, windoes burn, IMG Burn, all to no avail...... here,(, Avi2Dvd DVDStyler, ).
Funny, DVD Shrink would have done the trick.
Walter Lacey wrote:most profound thing I have learned, has been, a "subtitle" is storage for "Closed Captians for ........here("subtitle" is).
Storage? Closed Captions are a special case of subtitles, almost never found on DVDs.
ndjamena
#17 Post by ndjamena » Wed Apr 23, 2014 10:15 am
Chetwood wrote:Closed Captions are a special case of subtitles, almost never found on DVDs.
http://en.wikipedia.org/wiki/Closed_captioning wrote:The United Kingdom, Ireland, and most other countries do not distinguish between subtitles and closed captions, and use "subtitles" as the general term—the equivalent of "captioning" is usually referred to as "subtitles for the hard of hearing".
It depends on where you live. I've labelled all my SHD subtitles as Closed Captions, just because it sounds better...
Walter Lacey
#18 Post by Walter Lacey » Mon May 12, 2014 7:03 pm
ndjamena wrote:
Walter Lacey wrote:Closed Captions are a special case of subtitles, almost never found on DVDs.
Thanks ndjamena for much good info, but I did not write above, "a special case of subtitles, almost never found on DVDs". That was Chetwood's quote.
You were correct in advising DVDStyler. I have moved my problem to a new topic. See, "Failure moving, "Movie.mkv", onto DVD for a dvdplayer."
ndjamena
#19 Post by ndjamena » Mon May 12, 2014 10:30 pm
Sorry, I have no idea how that happened.
