I'm using the latest version of MakeMKV, but it repeatedly fails to save title to file for my blu-ray. I've tried 3 times. I've run a test dump, uploaded it on dropbox, and have emailed support@makemkv.com.
Thank you for your help.
-Connie.
Failed to save title to file multiple times.
Re: Failed to save title to file multiple times.
I'm having the same issues with version 1.810. I've gone back to version 1.89.
A_L
A_L
Operating System
Windows 8.1 64-bit
CPU
Intel Core i7 4820K @ 3.70GHz
RAM
32.0GB DDR3 @ 800MHz
Motherboard
ASUS SABERTOOTH X79
Graphics
3071MB NVIDIA GeForce GTX 780
Storage
100GB SSD
5X4TB HDD
Optical Drives
HL-DT-ST BD-RE BH14NS40
Windows 8.1 64-bit
CPU
RAM
Motherboard
ASUS SABERTOOTH X79
Graphics
Storage
100GB SSD
5X4TB HDD
Optical Drives
I had this also. Some more details:
Makemkv version 1.8.10 on Linux 64-bit
Size of track on BD - 33Gb
Rip appeared to proceed normally until the end, when it deleted the output file and reported "Failed to save file"
However on running it again and watching closely at the end, I found that the output file stopped growing 2 minutes from the end, when the output file was 32Gb
The progress bar kept going for the last two minutes, but the output being corrupt was deleted
Downgraded to 1.8.9, which worked fine.
Thanks for the info.slackbastard wrote:I had this also. Some more details:
Would you happen to have a link to where I can download the 1.8.9 version? I can't seem to find a link that works.
Thank you.
Old versions are always available here
/download/old/
/download/old/
Thank you!!slackbastard wrote:Old versions are always available here
/download/old/
