BR M.D. House Amazon-exclusive, German Version, S6 D2 errors
AdmiralFocke
#1 Post by AdmiralFocke » Mon Apr 21, 2014 8:41 pm
Dear,
MakeMKV 1.8.10 on MacOS X cannot copy disc 2 of Season 6 of German Amazon-exclusive M.D. House set:
MakeMKV v1.8.10 darwin(x86-release) started
Optical drive "BD-ROM HL-DT-ST BDDVDRW CT21N 1.00d" opened in OS access mode.
Backing up disc into folder "/Volumes/500GB USB3/S6D2"
Hash check failed for file /BDMV/STREAM/00005.m2ts at offset 5750581248, file is corrupt.
Hash check failed for file /BDMV/STREAM/00005.m2ts at offset 5750777856, file is corrupt.
Hash check failed for file /BDMV/STREAM/00005.m2ts at offset 5750974464, file is corrupt.
Hash check failed for file /BDMV/STREAM/00005.m2ts at offset 5751171072, file is corrupt.
Hash check failed for file /BDMV/STREAM/00005.m2ts at offset 5751367680, file is corrupt.
Too many hash check errors in file /BDMV/STREAM/00005.m2ts.
Hash check for /BDMV/STREAM/00005.m2ts : 39.16% corrupt, 60.83% correct, 99.99% checked.
Disc can be copied with AnyDVD, but MakeMKV still raises same errors after working on the ISO...
Any ideas?
Thanks, AF
ndjamena
Re: BR M.D. House Amazon-exclusive, German Version, S6 D2 er
#2 Post by ndjamena » Mon Apr 21, 2014 10:01 pm
I believe the point it's trying to make is that it can't verify 40% of the data in the file so it doesn't really know if it's correct or not. It probably could make a file out of it but...
AdmiralFocke
#3 Post by AdmiralFocke » Tue Apr 22, 2014 5:18 pm
Sorry,
forgot to mention that the track will not be saved (failed)...
#4 Post by Woodstock » Tue Apr 22, 2014 7:06 pm
If you Open the disk and try saving the titles as MKV files, do you get the same files being flagged as corrupt?
Mike's going to want debugging information, so check the FAQ linked in my signature to turn it on.
