Fatal error ripping Weeds Season 5, Disc 2
acosmichippo
Post by acosmichippo »
Hi there, i've been using MakeMKV with great results for a few months. Most errors i have come across seem to be remedied with updates except for one. While attempting to rip Weeds Season 5, Disc 2, i get a fatal error:
Debug log started at Sat Feb 13 07:00:59 2010 , written by MakeMKV v1.4.12 beta darwin(x86-release)
001005:0000 MakeMKV v1.4.12 beta darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/rolferikfredriksen/MakeMKV_log.txt
001003:0020 DEBUG: Code 0 at c8=GYK2UOqP:d5AyWRC8_&Ra=Hn:121265039
005053:0308 This functionality is shareware. You may evaluate it for 30 days after what you would need to purchase an activation key if you like the functionality. Do you want to start evaluation period now?
005050:0000 Evaluation version, 30 day(s) out of 30 remaining
001003:0020 DEBUG: Code 2 at HTq04a@0Z8\7/Xy1:213135343
001003:0020 DEBUG: Code 100806658 at Tep%9MV?0`YuYv}v.i:121263429
001003:0020 DEBUG: Code 100806658 at Tep%9MV?0`YuYv}v.i:29393654
002003:0000 Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occured while reading '00352.m2ts' at offset '36956160'
002003:0000 Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occured while reading '00274.m2ts' at offset '540672'
DISCID=078A17F11D8BC66E6256DAA9733A6BC103357539
003025:0000 Title #00183.mpls has length of 83 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003307:0000 File 00681.mpls was added as title #0
003307:0000 File 00682.mpls was added as title #1
003307:0000 File 00683.mpls was added as title #2
003307:0000 File 00684.mpls was added as title #3
003307:0000 File 00685.mpls was added as title #4
003307:0000 File 00686.mpls was added as title #5
001002:0020 LIBMKV_TRACE: No CC5 in 00688
001002:0020 LIBMKV_TRACE: No CC5 in 00504
003025:0000 Title #00003.mpls has length of 94 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
001002:0020 LIBMKV_TRACE: No CC5 in 00715
001002:0020 LIBMKV_TRACE: No CC5 in 00716
001002:0020 LIBMKV_TRACE: No CC5 in 00717
001002:0020 LIBMKV_TRACE: No CC5 in 00718
001002:0020 LIBMKV_TRACE: No CC5 in 00719
001002:0020 LIBMKV_TRACE: No CC5 in 00720
001002:0020 LIBMKV_TRACE: No CC5 in 00721
001002:0020 LIBMKV_TRACE: No CC5 in 00722
001002:0020 LIBMKV_TRACE: No CC5 in 00723
001002:0020 LIBMKV_TRACE: No CC5 in 00724
001002:0020 LIBMKV_TRACE: No CC5 in 00725
001002:0020 LIBMKV_TRACE: No CC5 in 00726
001002:0020 LIBMKV_TRACE: No CC5 in 00727
003025:0000 Title #00004.m2ts has length of 0 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 22 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 11 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00153.m2ts has length of 14 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00240.m2ts has length of 0 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00241.m2ts has length of 14 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00242.m2ts has length of 0 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00243.m2ts has length of 0 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00249.m2ts has length of 41 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00251.m2ts has length of 22 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00310.m2ts has length of 52 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00311.m2ts has length of 14 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00344.m2ts has length of 667 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00345.m2ts has length of 735 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00346.m2ts has length of 664 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00351.m2ts has length of 155 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00352.m2ts has length of 122 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00353.m2ts has length of 147 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00354.m2ts has length of 187 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00355.m2ts has length of 152 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00356.m2ts has length of 202 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00357.m2ts has length of 257 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00358.m2ts has length of 147 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00359.m2ts has length of 157 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00360.m2ts has length of 177 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00361.m2ts has length of 172 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00362.m2ts has length of 152 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00363.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00272.m2ts has length of 10 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00273.m2ts has length of 10 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00274.m2ts has length of 10 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
003025:0000 Title #00275.m2ts has length of 0 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
005011:0000 Operation sucessfully completed
005014:0000 Saving 6 titles into directory /Volumes/Temp Videos/DVD Rips/Weeds_Season_5_Disc_2
005001:0308 File /Volumes/Temp Videos/DVD Rips/Weeds_Season_5_Disc_2/title00.mkv already exist. Do you want to overwrite it?
002008:0020 Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
002003:0000 Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occured while reading '/BDMV/STREAM/00336.m2ts' at offset '6109065216'
001003:0020 DEBUG: Code 0 at 8XUao>&lqCz>~^z>:121268305
001003:0020 DEBUG: Code 100806658 at Tep%9MV?0`YuYv}v.i:213132445
001003:0020 DEBUG: Code 0 at hGY3dt}D1bKkT7xm'7A*:213130628
001003:0020 DEBUG: Code 0 at fzrA_cY]^l4+=-=PqYv/:213129823
001003:0020 DEBUG: Code 0 at hGY3dt}D1bKkT7xm'7A*:213130513
001003:0020 DEBUG: Code 2982942 at hGY3dt}D1bKkT7xm'7A*:213129639
001003:0020 DEBUG: Code 0 at O&^GS`#%eScL||)'zZ7Jf:121264993
Seems really weird to me since the first disc ripped with no issues at all. Is there anything in the log that could indicate what the problem is?
Thanks so much for any assistance.
Re: Fatal error ripping Weeds Season 5, Disc 2
Post by mike admin »
Can you please run MakeMKV without any disc in drive and insert the disc while MakemKV is running? If it doesn't help please try to eject the disc from MakeMKV menu and insert again.
