Beauty and the Beast bluray
joncar@tailwag.org
#1 Post by joncar@tailwag.org » Mon Apr 14, 2014 8:55 pm
Makemkv fails partway thru Beauty and the Beast blu ray rip . . . Can't seem to attached log file (board attachment quota has been reached).
Please help
Jay
Re: Beauty and the Beast bluray
#2 Post by Woodstock » Tue Apr 15, 2014 1:37 pm
You CAN still post the log information as part of the message, though. It's best if you click on the CODE button before you paste it in, though, so that the output stays readable (not doing so lets the software "fix" the text sometimes).
joncar@tailwag.org
#3 Post by joncar@tailwag.org » Sat Apr 19, 2014 12:48 am
Okay, thanks for advice; i'll try this again.
First, I did check disk for scratches/smudges. Disk will play in blu-ray player elsewhere in house, and will play on blu-ray drive on the pc I'm using for ripping. Since first attempting BATHB, I've successfully ripped two other blu-rays in same drive. The attempt below is from last night--about my 5th attempt with same results.
Below is the log. Any help appreciated.
Jay
MakeMKV v1.8.9 win(x86-release) started
Debug logging enabled, log will be saved as C:\Users\Administrator/MakeMKV_log.txt
The new version 1.8.10 is available for download at http://www.makemkv.com/download
Title #00270.mpls has length of 1218 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00271.mpls has length of 787 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00277.mpls has length of 1137 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00278.mpls has length of 544 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00253.mpls has length of 372 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00020.mpls has length of 495 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
File 00800.mpls was added as title #0
File 00801.mpls was added as title #1
Title 00802.mpls is equal to title 00800.mpls and was skipped
Title 00803.mpls is equal to title 00801.mpls and was skipped
Title #00021.mpls has length of 983 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00022.mpls has length of 983 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00023.mpls has length of 968 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00024.mpls has length of 968 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00025.mpls has length of 932 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00267.mpls has length of 459 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00269.mpls has length of 364 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00272.mpls has length of 1137 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00274.mpls has length of 544 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00273.mpls has length of 1137 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00275.mpls has length of 544 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00287.mpls has length of 131 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00000.m2ts has length of 0 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00011.m2ts has length of 11 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00075.m2ts has length of 0 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00076.m2ts has length of 0 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00250.m2ts has length of 64 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00259.m2ts has length of 20 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00012.m2ts has length of 24 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00026.m2ts has length of 264 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00027.m2ts has length of 231 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00252.m2ts has length of 7 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00028.m2ts has length of 24 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00029.m2ts has length of 24 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00030.m2ts has length of 258 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00034.m2ts has length of 231 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00035.m2ts has length of 5 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00031.m2ts has length of 47 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00032.m2ts has length of 47 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00033.m2ts has length of 222 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00037.m2ts has length of 230 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00810.m2ts has length of 58 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00817.m2ts has length of 58 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00813.m2ts has length of 195 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00814.m2ts has length of 137 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00815.m2ts has length of 998 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00816.m2ts has length of 307 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00811.m2ts has length of 3319 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00812.m2ts has length of 76 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00251.m2ts has length of 48 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00818.m2ts has length of 408 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00819.m2ts has length of 137 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00820.m2ts has length of 386 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00254.m2ts has length of 105 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00255.m2ts has length of 64 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00256.m2ts has length of 7 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00257.m2ts has length of 75 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00258.m2ts has length of 107 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00260.m2ts has length of 52 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00261.m2ts has length of 83 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00262.m2ts has length of 77 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00263.m2ts has length of 49 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00264.m2ts has length of 76 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00265.m2ts has length of 77 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00266.m2ts has length of 32 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00060.m2ts has length of 7 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00268.m2ts has length of 6 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00270.m2ts has length of 1218 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00271.m2ts has length of 787 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00277.m2ts has length of 1137 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00278.m2ts has length of 544 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00276.m2ts has length of 206 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00279.m2ts has length of 7 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00280.m2ts has length of 118 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00281.m2ts has length of 7 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00282.m2ts has length of 68 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00283.m2ts has length of 101 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00285.m2ts has length of 82 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00286.m2ts has length of 48 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00288.m2ts has length of 7 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00289.m2ts has length of 4 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00290.m2ts has length of 4 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00291.m2ts has length of 4 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00292.m2ts has length of 4 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00293.m2ts has length of 4 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00294.m2ts has length of 4 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00295.m2ts has length of 4 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Title #00036.m2ts has length of 3 seconds which is less than minimum title length of 4096 seconds and was therefore skipped
Saving 1 titles into directory //WDTVLIVEHUB/My_Book/video
AV synchronization issues were found in file '//WDTVLIVEHUB/My_Book/video/Beauty_and_the_Beast_(Disc_1)_t00.mkv' (title #1)
AV sync issue in stream 1,2,3 at 0:00:58.933 with duration of 10.125ms : encountered overlapping frame, audio skew is +10.125ms
Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00811.m2ts' at offset '2366177280'
DEBUG: Code 0 at bp1=eizf/.Ksl~Xb oOV:121262739
DEBUG: Code 0 at OM+MKh&Sb>y18EC$#7&?:121261888
DEBUG: Code 0 at bp1=eizf/.Ksl~Xb oOV:213130743
DEBUG: Code 1155360 at bp1=eizf/.Ksl~Xb oOV:29393332
DEBUG: Code 0 at SGr_n/1cY/geXBcn3c"CN:121266810
Failed to save title 0 to file //WDTVLIVEHUB/My_Book/video/Beauty_and_the_Beast_(Disc_1)_t00.mkv
0 titles saved, 1 failed
electronicsguy
#4 Post by electronicsguy » Wed Apr 23, 2014 1:33 am
I am not an expert but the last few errors indicate a standard hardware problem:
1. bad disc
2. bad drive
3. some power problem.
Rydsen
#5 Post by Rydsen » Wed Apr 23, 2014 11:09 pm
I had the same problem with my BatB blu ray where it would not finish the rip. It'd get about 2/3 through and fail every time. It wasn't scratched or damaged, I cleaned it, I've ripped literally hundreds and hundreds of other discs so I attributed it to a mastering error or something. I ended up just borrowing my friend's copy of the exact same disc and his ripped just fine the first try. I'm sorry it's not working for you.
