Issues with ST TNG Blu Ray and 1.810
Arnold_Layne
Post by Arnold_Layne »
With Version 1.810 titles from the ST TNG Blu Ray seasons will not save. Version 1.89 works fine. I believe the error happens right at the end of the title when there is another segment added to the end of each title. In version 1.810 I get debug codes and the file is not saved. In 1.89 I get AV sync messages, but the title is saved.
I sent a test dump to support@makemkv.com
Operating System
Windows 8.1 64-bit
CPU
Intel Core i7 4820K @ 3.70GHz
RAM
32.0GB DDR3 @ 800MHz
Motherboard
ASUS SABERTOOTH X79
Graphics
3071MB NVIDIA GeForce GTX 780
Storage
100GB SSD
5X4TB HDD
Optical Drives
HL-DT-ST BD-RE BH14NS40
Arnold_Layne
Re: Issues with ST TNG Blu Ray and 1.810
Season 4. First three I ripped with 1.89. I upgraded to 1.810 before I started ripping season 4. I have gone back to 1.89 and season 4 is ripping just fine.
Operating System
Windows 8.1 64-bit
CPU
RAM
Motherboard
ASUS SABERTOOTH X79
Graphics
Storage
100GB SSD
5X4TB HDD
Optical Drives
ndjamena
Post by ndjamena »
I converted up to series 4 on my first attempt, series 3 on my second and I guess I'll make my third attempt some time soon. Hopefully some time before series 7 is released I'll have the process down pat so I can finally watch the bloody thing after 20 something years (it was screened after midnight here in Australia, I missed at least one entire season and quite a few episodes for various reasons... it was my favourite show too before it was challenged by Buffy and probably still is!)
Doubleslash
Post by Doubleslash »
I have the same problem with discs from Season 5. But going back to 1.8.9 does not help. Even tried older version, same result, always: ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE or MEDIUM ERROR:UNRECOVERED READ ERROR.
Guess they have changed the encryption mechanism and we need to wait for 1.8.11 to fix it?
If there is a change in encryption, USUALLY there will be a link within the debugging window to forward information to Mike that will help overcome it.
Did you get such a link? If so, did you click on it to forward the information?
Doubleslash
No, I did not see such a link in 1.8.9 or 1.8.10. I tried 1.8.5 (which I happened to have on disk) when I saw this link. Seems to be something else then...
Post by mike admin »
This is a confirmed bug in 1.8.10 . The workaround is to use 1.8.9 (or if it fails to decrypt then make a decrypted full disc backup with 1.8.10 and use 1.8.9 to produce MKV file fro, backup).
Doubleslash
Any hint when we will see this fixed in 1.8.11 ?
zacwhite15
Post by zacwhite15 »
just to give you guys an update, i went back to 1.8.8 and i am no longer having issues ripping TNG seasons.
Doubleslash
Hi, unfortunately the errors regarding the copy protection persist. When I try to create backup of the disk and later decrypt I get
So, version 1.8.11 doesn't seem to fix the issue. Version 1.8.8 or 1.8.9 or 1.8.10 neither. Error message is
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while issuing SCSI command AD010..080002400 to device 'DASPI:IODASPIService:34e3deb9c98c2ddb:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0359E67D4E9EC0E2841AF7AE81F6DAA8578 to device 'DASPI:IODASPIService:34e3deb9c98c2ddb:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0794809FECB0AE91218DA56E28D9971FB9E to device 'DASPI:IODASPIService:34e3deb9c98c2ddb:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..001796B0E3744C9500A7639B3039F713E76 to device 'DASPI:IODASPIService:34e3deb9c98c2ddb:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..00B431FA39FC592203E1A2F0D88C4D11A59 to device 'DASPI:IODASPIService:34e3deb9c98c2ddb:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0938F0DDD1602A6E23DAB8E52184853BC0D to device 'DASPI:IODASPIService:34e3deb9c98c2ddb:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..02340B0D03485F0C1F1A861B33EE6BB6109 to device 'DASPI:IODASPIService:34e3deb9c98c2ddb:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'DASPI:IODASPIService:34e3deb9c98c2ddb:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..054C81BF28E25DD2696A057CF92433F6060 to device 'DASPI:IODASPIService:34e3deb9c98c2ddb:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..09668AE7CAB738FA0569BEF809B04796B50 to device 'DASPI:IODASPIService:34e3deb9c98c2ddb:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0C0DD18798A5A95C9B90A33317608AA5F23 to device 'DASPI:IODASPIService:34e3deb9c98c2ddb:'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..068D0135DB7DC619B3836326430EA4F4DB9 to device 'DASPI:IODASPIService:34e3deb9c98c2ddb:'
Regards,
Daniel
These errors occur before you get to the key exchange process:
Key exchange is the least of your worries right now; the drive thinks the disk isn't readable.
Doubleslash
This is strange - the drive worked like a charm on discs from season 1-4. Is this related to the drive being faulty?
If the errors are limited to certain disks, it is probably not the drive. That is, if you put one of the season 1 disks in and it reads it just fine, the drive is probably OK.
But that would point to the disks themselves having a problem. Hopefully, Mike can get information from the debug messages to figure this out.
Doubleslash
Well, ok - I guess it's related to the disks then. The problems started with Season 5. I don't have the discs of Season 1-4 anymore, so I cannot test ;)
But my gut feeling says they introduced a new encryption mechanism.
