Fatal error occured, programm will now exit-windows 7 64bit
trigger
I installed makemkv 1.4.12 and opened it straight away from the installer and it worked fine, I stopped it opening a bluray disk half way through, as wanted to check what the output folder was, now everytime I try and open makemkv I get the above message. I've tried re-installing numerous times with reboots in between. It seems somethings got currupted or the uninstall isn't removing everything, any suggestions.
Re: Fatal error occured, programm will now exit-windows 7 64bit
What happens if you right click on MakeMKV icon and select "run as administrator" ?
trigger
Same error. I tried that with and without when installing also. It looks like it doesnt quite unistall properly...is there some files I should try and remove manually and/or registery settings? It's weird because it worked the first time I ran the program
Please try to run a command-line version and see what happens: and
makemkvcon info disc:0Code: Select all
makemkvcon64 info disc:0-
trigger
C:\Program Files (x86)\MakeMKV2>makemkvcon info disc:0
001005:0000 MakeMKV v1.4.12 beta win(x86-release) started
Current action: Scanning CD-ROM devices
Total 0 titles
C:\Program Files (x86)\MakeMKV2>makemkvcon64 info disc:0
001005:0000 MakeMKV v1.4.12 beta win(x64-release) started
Total 0 titles
I tried re-running with a dvd in the drive and it came up with a plethora of details about the dvd. So it looks like the command line version works
Total 0 titles
Total 0 titles
trigger
I suppose I could just use the command line version but when you run it with info option, it doesnt give enough information about each title compared to the gui version e.g. how many chapters, is there a way of getting more info?
lowflow
Has anyone found a solution to this issue. I removed my codec pack - Shark007 - and things started to work again. However, I am not sure what has started to conflict after version 1.4.12. Is there any logs that might show what is conflicting with the Makemkv gui ? has anyone else found a solution to this problem?
What version of Shark007 did you install?lowflow wrote:I removed my codec pack - Shark007 - and things started to work again.
lowflow
I currently have Shark007 Windows 7 Codecs 2.4.1 (32bit) with x64 components version 2.4.7 - I am going to try the newer version today.mike admin wrote:What version of Shark007 did you install?lowflow wrote:I removed my codec pack - Shark007 - and things started to work again.
I have had this issue since installing 1.4.12.
version 1.4.11 worked when it was still available.
I really like your program and if I can get this work again, you can have my money for sure.
Any assistance would be appreciated
setarip_old
Have you folks tried the just released version of Make MKV - v.1.5.1b?
lowflow
setarip_old wrote:Have you folks tried the just released version of Make MKV - v.1.5.1b?
Yes, I have installed/reinstalled. rebooted ..Tried with different users on the same machine. Tried starting as Admin and User. Still failing.
I really really want this to work.
Please use instructions in this thread to sumbit a log - http://www.makemkv.com/forum2/viewtopic ... 3879#p3879
lowflow
Since the last release 1.5.2, all GUI issues are resolved.
Thanks a million Mike !
