MakeMKV won't open any Blu-Rays
TheMikeOfSteel
Post by TheMikeOfSteel »
I just installed MakeMKV 1.8.9 on a new Retina MacBook Pro 13” running Mavericks 10.9.2. I’m not able open any Blu-Rays.
When I launch the MakeMKV, the program gives me this error:
MakeMKV v1.8.9 darwin(x86-release) started
Error 'Scsi error - STATUS_05' occurred while issuing SCSI command 46020..00140 to device 'DASPI:IODASPIService:760b45dd0ec34ddb:'
Optical drive "PIONEER BD-RW BDR-XD04 1.00" opened in DASPI v1.4 mode.
If I choose “Open Files” I get this error:
Error 'Scsi error - STATUS_05' occurred while issuing SCSI command 46020..00140 to device 'DASPI:IODASPIService:3b4a84999b3e46f3:'
Error 'Scsi error - STATUS_05' occurred while issuing SCSI command 460200010..00100 to device 'DASPI:IODASPIService:3b4a84999b3e46f3:'
Opening files on harddrive at /Volumes/TAKEN
My external Blu-Ray drive appears to be working correctly. It works perfectly on an iMac running Mountain Lion. On the MacBook Pro, the drive shows up in the Finder and everything seems great.
It’s a Pioneer BDR-XD04 if that matters.
http://www.pioneerelectronics.com/PUSA/ ... s/BDR-XD04
Does anyone know how I can fix this issue? Any help is greatly appreciated.
DesertWolf29
Re: MakeMKV won't open any Blu-Rays
Post by DesertWolf29 »
Hmmm, this is just a hunch, but did you install the DASPI package included the DMG?
EminenceGrise
Post by EminenceGrise »
I ran into this problem too. The drive worked fine with Mavericks on a 2009 MacBook Pro, but not a newer 2013 MacBook Air. Might be because the newer machine is USB 3.0... Anyway, I was able to fix it by updating the firmware on the drive to version 1.30, which is available on Pioneer's Japanese site:
http://pioneer.jp/device_e/product-e/ib ... 01r_e.html
The US site had a newer version of firmware than I had on the drive, but not the latest 1.30. You'll need access to a Windows machine to do the update though, there isn't a Mac installer that I could find. So far I don't think it's broken anything either, though YMMV. :wink:
rickyjm
Post by rickyjm »
For your disk drive, is it through USB? Try to check the thread below.
http://www.makemkv.com/forum2/viewtopic.php?f=1&t=3445
Always back it up. Image
