Still not able to rip stereo LPCM in 1.8.9
arkadi
#1 Post by arkadi » Fri Feb 28, 2014 12:56 pm
With 1.8.9, I still cannot extract LPCM 2.0 audio tracks. It doesn't give an error message, as 1.8.8 did (http://www.makemkv.com/forum2/viewtopic.php?f=1&t=7551), but whenever I select an LPCM 2.0 track, the extraction seemingly starts, and makemkvcon continues to use about 30% cpu time, but no output is ever produced until I eventually stop the extraction.
005014:0000 Saving 1 titles into directory /export/scratch/bluerays
002003:0000 Error 'Internal error - Operation was cancelled (112)' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '1102215168'
(The error is due to the cancellation - no further log output is produced before that). Selecting LPCM 5.1 tracks works fine, even transcoding into FLAC, but not LPCM stereo. I also tried to convert this track to FLAC, but the behaviour is the same.
This happens on Fedora 20 (64bit), with makekmv compiled per the instruction from this forum. I also tried with ffmpeg 2.1.4, but that did not make any difference.
The BD in question is "2L The Nordic Sound" (Pure Audio Blu Ray)
Roman
Re: Still not able to rip stereo LPCM in 1.8.9
#2 Post by mike admin » Thu Mar 06, 2014 9:17 am
Please do a testdump per /onlinehelp/testdump.html
ndjamena
#3 Post by ndjamena » Wed Apr 16, 2014 1:48 am
I ripped Iron Man: Armored Adventures while my internet was down and came across the PCM issue. I just created a new profile and swapped "LPCM-raw" output to "directCopy" output and it seemed to work fine, (not that I used those rips in the end).
    <!--outputSettings name="lpcm" outputFormat="LPCM-raw"-->
    <outputSettings name="lpcm" outputFormat="directCopy">
