Hello everybody,
I just tried to convert the AVCHD Filestructure from my Panasonic HC-V500.
OS is Windows7 Ultimate N
I'd be happy to supply a sample recording.
Any ideas?
makemkv 1.8.9 can't read Panasonic HC-V500 AVCHD Files
- Contact:
Re: makemkv 1.8.9 can't read Panasonic HC-V500 AVCHD Files
Please check this - http://www.makemkv.com/forum2/viewtopic.php?f=8&t=7638 . But the filestructure from this camera would be welcomed anyway, please make a few 3-5 second recordings, compress the folder and send it to support@makemkv.com. Thank you.
1.8.10 is able to read it! Thanks for the fix.mike admin wrote:Please check this - http://www.makemkv.com/forum2/viewtopic.php?f=8&t=7638 . But the filestructure from this camera would be welcomed anyway, please make a few 3-5 second recordings, compress the folder and send it to support@makemkv.com. Thank you.
Will send you a sample.
Keep up the excellent work
