Blu Ray Won't Open
hosedagainx3
Blu Ray Won't Open
Post by hosedagainx3 »
I bought 2 Blu Rays, copied 1 with no problem, the second would not open, tried the first disc again and it would not open either. So tried another disc in my library and the same issue.
Is it my reader, LG, or ??? I tried a digital disc in the same reader and no issue, works fine. Any help would be appreciated
MakeMKV v1.7.10 win(x86-release) started
Debug logging enabled, log will be saved as C:\Documents and Settings\Owner/MakeMKV_log.txt
DEBUG: Code 101016576 at vpNUrO\:{:9X~es,&|:29396575
DEBUG: Code 101016576 at vpNUrO\:{:9X~es,&|:29393930
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/META/DL/bdmt_eng.xml' at offset '0'
DEBUG: Code 0 at N=2-g@wU`Uhjb:29394298
DEBUG: Code 0 at /){X^rtkwY+&2`z@1:213130329
DEBUG: Code 101016576 at vpNUrO\:{:9X~es,&|:213132100
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '4176992256'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '3594713088'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0EEBD55F57DB1E388E4ECA4DF35777C6B24 to device 'SPTI:\Device\CdRom2'
DEBUG: Code 0 at B@th:^k{$*$eXgK:q:213130743
DEBUG: Code 0 at t0V5NGn1Q>{AK"yL%j:29395034
DEBUG: Code 0 at t0V5NGn1Q>{AK"yL%j:121262394
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..068C89AD457C42C6CC5E9438C8C3A84EC46 to device 'SPTI:\Device\CdRom2'
DEBUG: Code 1 at t0V5NGn1Q>{AK"yL%j:121262394
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0183BE7DC9C63A9B185DD8F44013B6BE7CE to device 'SPTI:\Device\CdRom2'
DEBUG: Code 2 at t0V5NGn1Q>{AK"yL%j:121262394
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..09AD6B088E2620CBBAF5BD880AF36A80E6C to device 'SPTI:\Device\CdRom2'
DEBUG: Code 3 at t0V5NGn1Q>{AK"yL%j:121262394
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..043FFDA30B795A25221CE7C9378E66BE187 to device 'SPTI:\Device\CdRom2'
DEBUG: Code 4 at t0V5NGn1Q>{AK"yL%j:121262394
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..003AD3170C982672657DD1C35962BAAB86D to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0534B5931C03FEFC3566E976EF032D19706 to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0C0C040C818AD4966D8DFBD908B941CAB9D to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0C5C4B9803ABE0FD907D4BE60DACB195AB3 to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0543D8DB805B5481A16ED1311DA9902EA90 to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..029F4DCE9805B7D330E6D5D6B402B891236 to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..066807B6B36FE5F0790A6193364FD40618F to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0C3F356B8B31A7295F5B3E2C83E846ABD7F to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0E02E93382CE8B47A2907B7FF2569A90E77 to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0389EAE0DE6581E97255F27811654926EAD to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0903E7C19C874894CD283086C9A1DF8DE62 to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom2'
DEBUG: Code 0 at t0V5NGn1Q>{AK"yL%j:121264234
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0CF78D554469CCDB7FD77FFC4CE7BB0F684 to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..01CD31769C90F193492E4C043DB950A7F22 to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..00A2296921A883DBEC68DD4C03342533B8F to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..03C7E0B1A495D5F3345E032C54981CEAC35 to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..09F2A1BD78A6A579209F5BC8212E04BD917 to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..00A327B1885349799EA1E81C135022ADD0B to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0374D1D08B369EA94FB2EFCA5133FE9B191 to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..05194C8B85AE156FE37BD28101B88AEB461 to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..03F02229EF4D854A6640CE768F2EB2878A3 to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..035FFFF127547407063E2ACC43C4B5AFF84 to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0EF311645E932555B65D50C61D46C88B304 to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0FD6997F9AECDBC0474C17768E8E4FD544D to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0A56AD0E697E1D0D38E96165C19432E9750 to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0CDDCF7A2D40A54B1AA35F57424E4AF37B2 to device 'SPTI:\Device\CdRom2'
DEBUG: Code 0 at g-q+Rl&H!w%CW:zt:121263544
DEBUG: Code 0 at g-q+Rl&H!w%CW:zt:29396897
Reply, Reply All or Forward | More
Re: Blu Ray Won't Open
That's over 10 versions out of date. Download the current version and try again.
hosedagainx3
Thanks, re installed and works great, no issues
