MakeMKV crashes when setting preferences
nwhite04
Post by nwhite04 » Mon Apr 07, 2014 6:41 pm
I'm running the latest version of MakeMKV on Windows7 64-bit. When I launch the program I see this message:
MakeMKV v1.8.9 win(x64-release) started
Profile parsing error: default profile missing, using builtin default
If I try and set any preferences, when I click on Apply or OK the application crashes. Any idea what the issue is?
Re: MakeMKV crashes when setting preferences
Post by Woodstock » Mon Apr 07, 2014 11:49 pm
The file default.mmcp.xml, or whatever you have configured as your default profile, is not in your program directory, usually C:\Program Files (x86)\MakeMKV .
You can try reinstalling to get it back. It's copied in as part of the install, but it is possible that something overwrote it.
nwhite04
Post by nwhite04 » Tue Apr 08, 2014 8:14 am
Thanks. I have a Program Files directory on my D: drive which is where I had installed MakeMKV and it was causing problems. I reinstalled it on the C: drive and it's working fine now.
Regards,
