Rolling Stones - Grrr
Hubird
Post by Hubird » Mon Mar 31, 2014 9:05 am
This is a "High Fidelity Pure Audio " disc.
Can't rip all tracks.
MakeMKV v1.8.9 win(x64-release) started
Evaluation version, 23 day(s) out of 30 remaining
File 00001.mpls was added as title #0
Title #00002.m2ts has length of 110 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00004.m2ts was added as title #1
File 00005.m2ts was added as title #2
File 00006.m2ts was added as title #3
File 00007.m2ts was added as title #4
File 00008.m2ts was added as title #5
File 00009.m2ts was added as title #6
File 00010.m2ts was added as title #7
File 00011.m2ts was added as title #8
File 00012.m2ts was added as title #9
File 00013.m2ts was added as title #10
File 00014.m2ts was added as title #11
File 00015.m2ts was added as title #12
File 00016.m2ts was added as title #13
File 00017.m2ts was added as title #14
File 00018.m2ts was added as title #15
File 00019.m2ts was added as title #16
File 00020.m2ts was added as title #17
File 00021.m2ts was added as title #18
File 00022.m2ts was added as title #19
File 00023.m2ts was added as title #20
File 00024.m2ts was added as title #21
File 00025.m2ts was added as title #22
File 00026.m2ts was added as title #23
File 00027.m2ts was added as title #24
File 00028.m2ts was added as title #25
File 00029.m2ts was added as title #26
File 00030.m2ts was added as title #27
File 00031.m2ts was added as title #28
File 00032.m2ts was added as title #29
File 00033.m2ts was added as title #30
File 00034.m2ts was added as title #31
File 00035.m2ts was added as title #32
File 00036.m2ts was added as title #33
File 00037.m2ts was added as title #34
File 00038.m2ts was added as title #35
File 00039.m2ts was added as title #36
File 00040.m2ts was added as title #37
File 00041.m2ts was added as title #38
File 00042.m2ts was added as title #39
File 00043.m2ts was added as title #40
File 00044.m2ts was added as title #41
File 00045.m2ts was added as title #42
File 00046.m2ts was added as title #43
File 00047.m2ts was added as title #44
File 00048.m2ts was added as title #45
File 00049.m2ts was added as title #46
File 00050.m2ts was added as title #47
File 00051.m2ts was added as title #48
Re: Rolling Stones - Grrr
Post by Woodstock » Mon Mar 31, 2014 4:42 pm
Two tracks out of 51 were not selected due to them being shorter than the default minimum length of 2 minutes (120 seconds). If you want those two tracks, shorten your minimum track length in preferences. I use 30 seconds for what I do.
Although, you might find that the tracks not selected are part of the BD navigation menus.
Hubird
Post by Hubird » Mon Mar 31, 2014 10:39 pm
Arrh...
I thought there should be a setting for that but must have missed it.
Thanks.
