Error opening Bluray folder copy
HakanL
Post by HakanL »
First I must say that LOVE your program, it's exactly what I've been looking for!
But I have an issue, I've ripped a Bluray movie (CARS usa) using AnyDVD HD to disk in a folder structure (ie not iso). I point MakeMKV to the index.bdmv or MovieObject.bdmv file and I get the error below:
FAILURE: Code 3 at >f0]:TW#V uho<iN'4rT{qyWO:121261727
FAILURE: Code 0 at IXUcGJ0 YJtbB3I8:121265039
FAILURE: Code 0 at IXUcGJ0 YJtbB3I8:29394068
I'm using MakeMKV version 1.2.
Thanks,
/Hakan
Re: Error opening Bluray folder copy
Post by mike admin »
Hakan,
Please download the latest build 692 with this error fixed. It should help!
HakanL
Post by HakanL »
Ok, thanks, I'll give that a try!
HakanL
Post by HakanL »
Worked! However I do get a few errors, full log:
AACS directory not present, assuming unencrypted disc
Title #0 has length of 42 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #1 has length of 30 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 35 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 35 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 35 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 9 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 30 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 29 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 32 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #9 has length of 32 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #10 has length of 30 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #11 has length of 30 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #12 has length of 30 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #13 has length of 30 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #14 has length of 30 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #15 has length of 30 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #16 has length of 30 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #17 has length of 30 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #18 has length of 30 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #19 has length of 30 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #20 has length of 1 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #21 has length of 1 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #35 has length of 104 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #37 has length of 103 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #39 has length of 46 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #41 has length of 96 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #43 has length of 7 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #44 has length of 9 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #45 has length of 7 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Stream #1 of type 'LPCM-HD audio' was skipped, since it is not supported in BETA version
Title #49 has length of 1 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #50 has length of 0 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #51 has length of 85 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #52 has length of 2 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #53 has length of 2 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #54 has length of 2 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #55 has length of 114 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #58 has length of 1 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Title #60 has length of 0 seconds which is less then minimum title length of 120 seconds and was therefore skipped
Operation sucessfully completed
Saving 1 titles into directory G:/Video
FAILURE: Code 0 at <%xhpsk7~^c-T>\&-3[:121262601
1 titles saved
Hakan,
These errors are harmless, if you disable debug messages you would not even see them:)
HakanL
Post by HakanL »
Ah, ok, good, thanks!
