The version 1.8.9 has a confirmed bug that prevents opening some (relatively rare) blu-ray discs. Opening the disc would fail almost instantly with an error log similar to the log below
001003:0020 DEBUG: Code 0 at ob$R(eL]7w[j'4:213138793
001003:0020 DEBUG: Code 0 at e+3b-`N+SaUu3w]P:121265867
001003:0020 DEBUG: Code 0 at e+3b-`N+SaUu3w]P:29395011
001003:0020 DEBUG: Code 0 at e+3b-`N+SaUu3w]P:29397288
- * Make a non-decrypted full disc backup (skip if you already have files on a harddrive)
* Navigate to the folder with the backup, then navigate inside BDMV directory.
* Create an empty folder called "JAR" (no quotes, all-uppercase) inside the BDMV directory
* Open the backup in MakeMKV - it should work this time
