Stuttering MKVs Since 1.8.9
ymisyd
Post by ymisyd »
The last four discs I have ripped using 1.8.9 all stutter when streamed to my Panasonic Viera (they play fine on the computer). The video seems to pause for a fraction of a second every second or two of playback.
Any ideas?
Many thanks,
Mark
ymisyd
Re: Stuttering MKVs Since 1.8.9
Post by ymisyd »
I've tried converting with the WDTV profile instead of default - no change.
Chetwood
Post by Chetwood »
The only thing the WDTV profile does, is compress PGS subs with zlib. My rips with 1.8.9 don't stutter.
twa000
Post by twa000 »
how are you streaming LAN or WiFi connection?
The stuttering sounds like a typical issue when streaming across either a bad LAN connection using powerplugs or HD across WiFi which doesn't go.
