The last four discs I have ripped using 1.8.9 all stutter when streamed to my Panasonic Viera (they play fine on the computer). The video seems to pause for a fraction of a second every second or two of playback.
Any ideas?
Many thanks,
Mark
Stuttering MKVs Since 1.8.9
Re: Stuttering MKVs Since 1.8.9
I've tried converting with the WDTV profile instead of default - no change.
The only thing the WDTV profile does, is compress PGS subs with zlib. My rips with 1.8.9 don't stutter.
how are you streaming LAN or WiFi connection?
The stuttering sounds like a typical issue when streaming across either a bad LAN connection using powerplugs or HD across WiFi which doesn't go.
