Six Feet Under - Box - S1 D4
AdmiralFocke
Post by AdmiralFocke »
Hi there,
MakeMKV 1.8.9 on MacOS X only finds one (the third) of three episodes on this disk. All episodes can be played with MS Media Player.
Calculated BUP offset for VTS #0 does not match one in IFO header.
IFO file for VTS #1 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #2 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
IFO file for VTS #3 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Title #3 was added (7 cell(s), 0:54:53)
Title #4 has length of 1 seconds which is less than minimum title length of 15 seconds and was therefore skipped
DVD Structure setting is on "Automatic".
Any help much appreciated,
Admiral Focke
Re: Six Feet Under - Box - S1 D4
If you still have version 1.8.7 handy, try that. I'm finding a lot of disks that exhibit this behavior with 1.8.9, but work just fine with 1.8.7. Just finished ripping a set a few minutes ago that needed 1.8.7.
AdmiralFocke
This worked. Thank you,
-A. F.
