Fruits Basket Disc 1
DGGGG
Post by DGGGG »
Hey everyone,
Here is the error report:
Debug log started at Fri Feb 28 21:43:46 2014 , written by MakeMKV v1.8.9 win(x64-release)
001005:0000 MakeMKV v1.8.9 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\David/MakeMKV_log.txt
003025:0000 Title #1 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #3 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #4 has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #10 was added (1 cell(s), 0:02:00)
003019:0000 Cells 37-end were skipped due to cell commands (structure protection?)
Title skip vts=7 pgcn=1 hash=4E4BF1FC4AB0D059
Application exited at Fri Feb 28 21:46:12 2014
Any Help would be hot.
Re: Fruits Basket Disc 1
Which edition of Fruits Basket? I own that series, and ripped it many MakeMKV versions ago, so I can pull it out of my archives to see if there is a problem with the current version.
DGGGG
Post by DGGGG »
When I open the disc:
Current profile: DVD-ROM
Product: BD-RE BH14NS40
Revision: 1.00
Serial number: K9LC3763555
Firmware date: 2112-01-17 14:01:
Highest AACS version: 19
Disc Information
Label: Fruits_Basket_D1
Timestamp: 2011-04-27 13:58:10
Data capacity: 7.65 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
This is listed on Funimation as the February 2014 Edition.
That matches the version I have here.
And, when run through 1.8.7, it finds the main title with all 7 episodes; version 1.8.9 does NOT find the main file, though!
I'm going to create two debug dumps for Mike, 1 for 1.8.7, and one for 1.8.9.
First, V1.8.9:
Debug log started at Tue Mar 18 00:00:28 2014 , written by MakeMKV v1.8.9 win(x64-release)
003025:0000 Title #1 has length of 6 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #3 has length of 14 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003028:0000 Title #4 was added (1 cell(s), 0:01:01)
Application exited at Tue Mar 18 00:05:10 2014
Next, V1.8.7:
Debug log started at Tue Mar 18 00:07:01 2014 , written by MakeMKV v1.8.7 win(x64-release)
001005:0000 MakeMKV v1.8.7 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\jeffb/MakeMKV_log.txt
005075:0000 The new version 1.8.9 is available for download at http://www.makemkv.com/download
003028:0000 Title #11 was added (36 cell(s), 2:46:34)
001002:0020 LIBMKV_TRACE: Test dump mode on
005015:0000 Saving 3 titles into directory C:/RippedVideo/ using profile 'New' from file 'C:\Program Files (x86)\MakeMKV/New.mmcp.xml'
005005:0080 3 titles saved
005036:0104 Copy complete. 3 titles saved.
Application exited at Tue Mar 18 00:41:58 2014
If Mike reads this and needs it, I did a TESTDUMP with 1.8.7, and have the files available.
But, short-term, you can pull up 1.8.7 and do the rip. http://www.makemkv.com/download/old/
DGGGG
Post by DGGGG »
Great,
Thanks so much Jeff.
How would we know if Mike reads this or integrates it into the next version?
Would there be any real advantage to waiting until version 1.9 to rip?
Thanks Again
Post by mike admin »
1.8.7 is as good for DVD sources.
Mike, do you require any additional information to debug this? I have the testdump files from 1.8.7 created, and can supply the IFO files from the disk, before I put it back into storage...
Yes, please send a testdump from 1.8.7 . Thanks!
Zip file created, posted, and link sent to svq@makemkv.com ...
