The.Man.Who.Fell.To.Earth.1976.BD50:0 titles saved, 1 failed
11201ny
Post by 11201ny »
MakeMKV v1.8.8 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/KM/MakeMKV_log.txt
Optical drive "BD-RE HL-DT-ST BD-RE WH16NS40 1.00" opened in DASPI v1.4 mode.
The new version 1.8.9 is available for download at /download
DEBUG: Code 0 at Xo]NVfPl<w]:zb`\lUh8{-Dd6:213131318
Opening files on harddrive at /Volumes/4000GB 1/PTP/The.Man.Who.Fell.To.Earth.1976.BD50
DEBUG: Code 0 at 9`GD@tlghf#]`3*z:29396943
AACS directory not present, assuming unencrypted disc
File 00000.mpls was added as title #0
File 00005.mpls was added as title #1
File 00009.mpls was added as title #2
File 00021.mpls was added as title #3
File 00100.mpls was added as title #4
File 00768.mpls was added as title #5
File 00778.mpls was added as title #6
File 00004.m2ts was added as title #7
Title #00005.m2ts has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 113 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00008.m2ts was added as title #8
Title #00009.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00012.m2ts was added as title #9
File 00013.m2ts was added as title #10
File 00014.m2ts was added as title #11
Title #00017.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00231.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00233.m2ts has length of 58 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00248.m2ts has length of 73 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Volumes/4000GB 1/MOVIES (TEMP)/MakeMKV
DEBUG: Code 402832256 at E`7<gT{9|;*q!";?k)4<:213137160
DEBUG: Code 0 at E`7<gT{9|;*q!";?k)4<:121268972
DEBUG: Code 0 at {\"enh{o9tu$^a,:121263429
DEBUG: Code 1 at {weTEN\zOLR`4?ik:(:213131272
DEBUG: Code 0 at {weTEN\zOLR`4?ik:(:121263084
LIBMKV_TRACE: Specified conversion filter (68:A_PCM/INT/LIT->LPCMraw) is not available
DEBUG: Code 0 at {weTEN\zOLR`4?ik:(:213132560
DEBUG: Code 0 at {weTEN\zOLR`4?ik:(:29397794
DEBUG: Code 0 at {weTEN\zOLR`4?ik:(:213135251
DEBUG: Code 0 at {weTEN\zOLR`4?ik:(:121267914
Failed to save title 0 to file /Volumes/4000GB 1/MOVIES (TEMP)/MakeMKV/The_Man_Who_Fell_to_Earth_t00.mkv
Re: The.Man.Who.Fell.To.Earth.1976.BD50:0 titles saved, 1 fa
The new version 1.8.9 is available for download at ....
Known issue with 1.8.8, fixed in 1.8.9.
11201ny
Post by 11201ny »
:mrgreen:
