Iron Man 3 - AACS problem?
This is it
#1 Post by This is it » Sat Mar 15, 2014 8:40 am
when I try to ripp Iron Man 3, the following problem comes after 50%:
001003:0020 DEBUG: Code 1073741829 at }&vJ[\m9j;rrYiVG:29393953
001003:0020 DEBUG: Code 2 at 0?_16D9C HCZ(zN7:213137827
001003:0020 DEBUG: Code 2049 at SNJ2,{nvw;ERuA(?:213139920
002003:0000 Fehler 'SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' trat auf w?hrend des Auslesens von '/BDMV/STREAM/00000.m2ts' bei Offset '21466773504'
001003:0020 DEBUG: Code 513 at SNJ2,{nvw;ERuA(?:213139920
002003:0000 Fehler 'SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' trat auf w?hrend des Auslesens von '/BDMV/STREAM/00000.m2ts' bei Offset '21467037696'
002003:0000 Fehler 'SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' trat auf w?hrend des Auslesens von '/BDMV/STREAM/00000.m2ts' bei Offset '21469593600'
002003:0000 Fehler 'SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' trat auf w?hrend des Auslesens von '/BDMV/STREAM/00000.m2ts' bei Offset '21470183424'
002003:0000 Fehler 'SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' trat auf w?hrend des Auslesens von '/BDMV/STREAM/00000.m2ts' bei Offset '21473654784'
001003:0020 DEBUG: Code 4097 at SNJ2,{nvw;ERuA(?:213139920
002003:0000 Fehler 'SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' trat auf w?hrend des Auslesens von '/BDMV/STREAM/00000.m2ts' bei Offset '21473980416'
001003:0020 DEBUG: Code 0 at [w>eRC6mSw2Ow}Y.09/0:121262739
001003:0020 DEBUG: Code 0 at 1vw?1{Gf+%i |%"tRt0Y:121261888
001003:0020 DEBUG: Code 0 at [w>eRC6mSw2Ow}Y.09/0:213130743
001003:0020 DEBUG: Code 10485342 at [w>eRC6mSw2Ow}Y.09/0:29393332
001003:0020 DEBUG: Code 0 at hqPUB,7hr_`X~hSbzMk:S:121266810
Can you help me?
My english isn't the best. Sorry for this.
Re: Iron Man 3 - AACS problem?
#2 Post by Woodstock » Sun Mar 16, 2014 12:03 am
Not AACS, but common failure to read. There are parts of the disk that the drive cannot correctly decode.
Most likely causes are scratches or dirt on the disk, although it is possible that there is a problem with the drive (not as likely, but possible).
I keep Pledge furniture polish and a soft cotton cloth handy to clean and wax disks when things like this happen, especially if anyone else has handled it. Most of the time, it takes care of the problem.
Sometimes, I have to use a different drive; slight differences in how a laser is aligned can make a large difference in reading disks that are marginal. Scratched DVDs often work better in a DVD drive than a BD drive, because of the color of the laser used.
This is it
#3 Post by This is it » Sun Mar 16, 2014 12:09 am
Ok, thank you. I try to clen the BD.
