Select all english & spanish audio and subtitles by default?
kwanbis
Post by kwanbis » Thu Mar 13, 2014 4:10 pm
Is it possible to make makemkv (GUI) select ALL and ONLY spanish and english audio and subtitle, forced and unforced?
Is it possible to do the same but ignoring all commentary audio an subs?
THANKS!
Re: Select all english & spanish audio and subtitles by defa
Post by Woodstock » Thu Mar 13, 2014 8:26 pm
Tools->General, click "Expert mode".
Tools->Advanced, Default selection rule can be entered. I use one that selects ALL audio and subtitle tracks, but it would respond differently if I selected a preferred language on the Tools->Language tab:
-sel:all,+sel:(favlang|nolang),-sel:(havemulti|havecore),-sel:mvcvideo,=100:all,-10:favlang
kwanbis
Post by kwanbis » Fri Mar 14, 2014 2:10 pm
Thanks, but that is the exact default string, would that do what it want, select both spanish and english audio a subs (if possible ignoring commentary)?
Chetwood
Post by Chetwood » Fri Mar 14, 2014 2:48 pm
It cannot ignore commentary cause those streams are not designated as such in authoring. Often you can recognize them by bein 2.0 audio but some of the audio description tracks for blind people are also 5.1 HD so you need to check them out manually.
kwanbis
Post by kwanbis » Fri Mar 14, 2014 4:16 pm
Chetwood wrote:It cannot ignore commentary cause those streams are not designated as such in authoring. Often you can recognize them by bein 2.0 audio but some of the audio description tracks for blind people are also 5.1 HD so you need to check them out manually.
Ok then, so what string would select ALL and ONLY english and spanish audio and sub tracks?
Chetwood
Post by Chetwood » Sat Mar 15, 2014 6:33 am
-sel:all,+sel:(esp|eng|nolang)
should do it.
kwanbis
Post by kwanbis » Sat Mar 15, 2014 7:54 pm
Chetwood wrote:-sel:all,+sel:(esp|eng|nolang)
should do it.
Thanks, but somehow it does not works. Also, Mpeg4-MVC-3D streams are not selected. Any ideas?
kwanbis
Post by kwanbis » Tue Mar 18, 2014 5:14 pm
should do it.
Anyone?
eelisland
Post by eelisland » Fri Mar 21, 2014 1:59 pm
I have also bang my head recently with this, and i have some examples, hope this help :)
WARN: i don't use the PREFERED LANGUAGE option, i.e prefered language = none in the Preference.
You can also add at the end:
+sel:attachment
to extract the .jpg picture included in some disk
To verify if it suit you, just load a movie and see which subtitles and audio tracks are selected or not, no need to convert to MKV.
All elements are detailed here: http://www.makemkv.com/forum2/viewtopic ... 386#p17399
Example 1:
audio:fra, anglais, pol, +others, -comment
sub: fra,fra forced,pol, pol forced, eng, eng forced,+others
-sel:all,+sel:subtitle,-100:(fra),-99:(forced*(fra)),-95:(pol),-94:(forced*(pol)),-90:(eng),-89:(forced*(eng)),+sel:audio,-sel:special,-100:(audio*(fra)),-95:(audio*(pol)),-90:(audio*(eng))
Example 2:
audio:ang,fra,+others,-comment
sub:fra, fra forced,ang, ang forced,+others
-sel:all,+sel:subtitle,-100:(fra),-99:(forced*(fra)),-95:(eng),-94:(forced*(eng)),+sel:audio,-sel:special,-100:(audio*(ang)),-95:(audio*(fra))
Example 3:
audio:fra, anglais, pol, -comment
sub: fra,fra forced, pol, pol forced, eng, eng forced
-sel:all,+sel:(subtitle*(fra|pol|eng|nolang)),-100:(fra),-99:(forced*(fra)),-95:(pol),-94:(forced*(pol)),-90:(eng),-89:(forced*(eng)),+sel:(audio*(fra|pol|eng|nolang)),-sel:special,-100:(audio*(fra)),-95:(audio*(pol)),-90:(audio*(eng))
Example 4:
audio:fra, anglais, pol, und, nolang, +others, -comment
sub: fra,fra forced, pol, pol forced, eng, eng forced, und, nolang, +others
-sel:all,+sel:(subtitle*(fra|pol|eng|und|subtitle|nolang)),-100:(fra),-99:(forced*(fra)),-95:(pol),-94:(forced*(pol)),-90:(eng),-89:(forced*(eng)),+sel:(audio*(fra|pol|eng|und|audio|nolang)),-sel:(havemulti|havecore),-sel:mvcvideo,-sel:special,-100:(audio*(fra)),-95:(audio*(pol)),-90:(audio*(eng))
note: und stand for undetermined.
kwanbis
Post by kwanbis » Sun Apr 20, 2014 4:17 pm
Thanks, I tried to follow your examples and the "guide" (to call it some way), but it is not working.
I tried something simple first:
-sel:all,+sel:(eng|esp|und|nolang),+sel:mvcvideo,+sel:attachment,-sel:(special)
This should, unselect all, then select all english, espanis, undefined and nolang tracks (subs and audio), select 3d vide, select attachment, and unselect all special tracks, but it doesn't works.
Any idea?
kwanbis
Post by kwanbis » Wed Apr 23, 2014 5:54 pm
no one?
eelisland
Post by eelisland » Wed Apr 23, 2014 6:47 pm
Don't use esp
use spa instead:
-sel:all,+sel:(eng|spa|und|nolang),+sel:mvcvideo,+sel:attachment,-sel:(special)
List of languages codes here:
http://forum.doom9.org/showthread.php?t=155762
Hope that help
kwanbis
Post by kwanbis » Fri Apr 25, 2014 7:35 pm
Come on guys, I thought this was the official MakeMKV support forum!
eelisland
Post by eelisland » Fri Apr 25, 2014 9:21 pm
Hello Kwanbis,
I have responded to the thread, i have added a link to my answer and i think this need a moderator approval, anyway i have also responded to you in PM
I will answer here again, use:
spa
instead of
esp
esp is not a valid bd langue code, hope this help
kwanbis
Post by kwanbis » Fri Apr 25, 2014 10:00 pm
eelisland wrote:use:
spa
instead of
esp
Thanks! That did it, so now I have:
-sel:all,+sel:(eng|spa|und|nolang),-sel:(havemulti),+sel:mvcvideo,+sel:attachment,-sel:special
