Not sure what you mean by standalone to off? It seems if I ripped the DVD (using CloneDVD) with subtitles which it looks like I did most of the time, then the MKV after conversion has them 'burnt-in'? When I play the MKV I couldn't turn off the subtitles, I was able to open the file in the MKVTOOLS utility and un-select the subtitles and re-mux but that seems like a lot of manual work for the 600 odd movies in my collectionChetwood wrote:Forced subtitles are a complicated issue, I'm not even sure MakeMKV recognizes them from DVDs, so I wouldn't get may hopes out. Set your standalone to OFF and when you watch Avatar or something, turn them on manually.
