Problems since MakeMKV 1.8.7 and playing mkv with XBMC
spl83
#1 Post by spl83 » Mon Mar 10, 2014 7:34 pm
Hello!
I have a Problem with playing my .mkv Files since MakeMKV 1.8.7.
When i Play the File with XBMC the file hangs. There seems to be a Problem with the audio Tracks.
Since MakeMKV 1.8.7 XBMC can?t play the lossless audio files. When i switch from lossless audio to stereo everything is fine and xbmc plays the .mkv correctly.
I ripped "The Heat" with MakeMKV 1.8.6 and everything went fine:
(MKVInfo) + EBML-Kopf
(MKVInfo) |+ EBML-Version: 1
(MKVInfo) |+ EBML Leseversion: 1
(MKVInfo) |+ Maximale EBML-ID-L?nge: 4
(MKVInfo) |+ Maximale L?nge des EBML-L?ngenattributes: 8
(MKVInfo) |+ Dokumententyp: matroska
(MKVInfo) |+ Dokumententyp Version: 2
(MKVInfo) |+ Dokumententyp Leseversion: 2
(MKVInfo) + Segment, Gr??e 22860155764
(MKVInfo) |+ Suchkopf
(MKVInfo) | + Sucheintrag
(MKVInfo) |  + Such-ID: 0x15 0x49 0xa9 0x66 (KaxInfo)
(MKVInfo) |  + Suchposition: 1134
(MKVInfo) |  + Such-ID: 0x16 0x54 0xae 0x6b (KaxTracks)
(MKVInfo) |  + Suchposition: 1285
(MKVInfo) |  + Such-ID: 0x1c 0x53 0xbb 0x6b (KaxCues)
(MKVInfo) |  + Suchposition: 22860000789
(MKVInfo) |  + Such-ID: 0x10 0x43 0xa7 0x70 (KaxChapters)
(MKVInfo) |  + Suchposition: 1755
(MKVInfo) | + EbmlVoid (Gr??e: 19)
(MKVInfo) |+ EbmlVoid (Gr??e: 1021)
(MKVInfo) |+ Segment-Information
(MKVInfo) | + Zeitstempelskalierungsfaktor: 1000000
(MKVInfo) | + Muxeranwendung: libmakemkv v1.8.6 (1.2.0/1.1.0) win(x64-release)
(MKVInfo) | + schreibende Anwendung: MakeMKV v1.8.6 win(x64-release)
(MKVInfo) | + Dauer: 7220.087s (02:00:20.087)
(MKVInfo) | + Titel: Taffe M?dels
(MKVInfo) | + Datum: Wed Nov 13 19:29:21 2013 UTC
(MKVInfo) | + Segment-UID: 0xb3 0xca 0x56 0x27 0xed 0xe2 0x47 0xeb 0xbd 0xa7 0x34 0xe0 0xd9 0xaa 0x16 0x97
(MKVInfo) |+ Segmentspuren
(MKVInfo) | + eine Spur
(MKVInfo) |  + Spurnummer: 1 (Spur-ID f?r Mkvmerge & Mkvextract: 0)
(MKVInfo) |  + Spur-UID: 1
(MKVInfo) |  + Spurtyp: video
(MKVInfo) |  + Standardspur-Schalter: 0
(MKVInfo) |  + Schalter f?r Paketb?ndelung: 0
(MKVInfo) |  + MinCache: 1
(MKVInfo) |  + Codec-ID: V_MPEG4/ISO/AVC
(MKVInfo) |  + private Codec-Daten, L?nge 133 (h.264-Profil: High @L4.1)
(MKVInfo) |  + Standarddauer: 41.708ms (23.976 Bilder/Felder pro Sekunde im Falle einer Videospur)
(MKVInfo) |  + Videospur
(MKVInfo) |   + Pixelbreite: 1920
(MKVInfo) |   + Pixelh?he: 1080
(MKVInfo) |   + Anzeigebreite: 1920
(MKVInfo) |   + Anzeigeh?he: 1080
(MKVInfo) |  + Spurnummer: 2 (Spur-ID f?r Mkvmerge & Mkvextract: 1)
(MKVInfo) |  + Spur-UID: 2
(MKVInfo) |  + Spurtyp: audio
(MKVInfo) |  + Codec-ID: A_DTS
(MKVInfo) |  + Sprache: deu
(MKVInfo) |  + Standarddauer: 10.667ms (93.750 Bilder/Felder pro Sekunde im Falle einer Videospur)
(MKVInfo) |  + Name: 3/2+1
(MKVInfo) |  + Audio track
(MKVInfo) |   + Abtastrate: 48000
(MKVInfo) |   + Kan?le: 6
(MKVInfo) |  + Spurnummer: 3 (Spur-ID f?r Mkvmerge & Mkvextract: 2)
(MKVInfo) |  + Spur-UID: 3
(MKVInfo) |  + Sprache: eng
(MKVInfo) |  + Name: Lossless
(MKVInfo) |   + Farbtiefe: 24
(MKVInfo) |  + Spurnummer: 4 (Spur-ID f?r Mkvmerge & Mkvextract: 3)
(MKVInfo) |  + Spur-UID: 4
(MKVInfo) |  + Spurtyp: subtitles
(MKVInfo) |  + Codec-ID: S_HDMV/PGS
(MKVInfo) |  + Spurnummer: 5 (Spur-ID f?r Mkvmerge & Mkvextract: 4)
(MKVInfo) |  + Spur-UID: 5
(MKVInfo) |  + Spurnummer: 6 (Spur-ID f?r Mkvmerge & Mkvextract: 5)
(MKVInfo) |  + Spur-UID: 6
(MKVInfo) | + EbmlVoid (Gr??e: 35)
(MKVInfo) |+ Kapitel
And here is R.E.D2 with the sound problem:
(MKVInfo) + Segment, Gr??e 25216504076
(MKVInfo) |  + Suchposition: 1277
(MKVInfo) |  + Suchposition: 25216367720
(MKVInfo) |  + Suchposition: 1778
(MKVInfo) | + Muxeranwendung: libmakemkv v1.8.7 (1.3.0/1.4.1) win(x64-release)
(MKVInfo) | + schreibende Anwendung: MakeMKV v1.8.7 win(x64-release)
(MKVInfo) | + Dauer: 6964.999s (01:56:04.999)
(MKVInfo) | + Titel: RED 2
(MKVInfo) | + Datum: Fri Jan 31 10:06:50 2014 UTC
(MKVInfo) | + Segment-UID: 0x74 0x44 0x65 0xad 0x8a 0xc3 0x27 0xa0 0x6f 0x9c 0x18 0x36 0x7e 0x5c 0x01 0x0f
(MKVInfo) |  + private Codec-Daten, L?nge 72 (h.264-Profil: High @L4.1)
(MKVInfo) |  + Standardspur-Schalter: 1
(MKVInfo) |  + Schalter f?r Paketb?ndelung: 1
(MKVInfo) |   + Kan?le: 8
(MKVInfo) |   + Farbtiefe: 16
(MKVInfo) |  + Spurnummer: 6 (Spur-ID f?r Mkvmerge & Mkvextract: 3)
(MKVInfo) |  + Spurnummer: 7 (Spur-ID f?r Mkvmerge & Mkvextract: 4)
(MKVInfo) |  + Spur-UID: 7
(MKVInfo) |  + Spurnummer: 8 (Spur-ID f?r Mkvmerge & Mkvextract: 5)
(MKVInfo) |  + Spur-UID: 8
Diffrences between the 2 MKV i found:
I miss the following 2 settings in the german language part:
Or whats wrang here and can i fixe it?!
spl83
Re: Problems since MakeMKV 1.8.7 and playing mkv with XBMC
#2 Post by spl83 » Tue Mar 11, 2014 12:56 pm
Or is the Problem just the Name of the Audio track?
R.E.D 2 with stutter Problems:
The HEAT which works fine:
Don?t know whats wrong and how i can fix it :(
Any ideas?
spl83
#3 Post by spl83 » Thu Mar 13, 2014 6:39 pm
Hi!
I solved the Problem after several hours of trying.... It?s no Problem with makemkv!!!
The 2 Films where the first one i ripped with DTS HD Master Audio 7.1 Channel (before i only had 5.1 channels) .
So, in XBMC i must use the "Wasapi hdmi pathtrough" option to path through this 7.1 channel audio over hdmi.
So everything fine, for now! And i have no more stuttering.
