MakeMKV for Popcorn Hour C-200
pvdwaal
Post by pvdwaal » Tue Oct 27, 2009 11:57 am
Is it possible to make a build for the new PCH C-200?
On networkedmediatank.com I've got a thread on it: http://www.networkedmediatank.com/showt ... #pid276867
Main problem is that C-200 has subtitle issues, but not with mkv files.
I use the usenet client on the C-200 all the time, so all my content is directly saved on the internal HDD.
To make a mkv on my PC is not really an option, because coping 20GB for each m2ts movie to PC and back takes much to long over 100mbit.
When I can start MakeMKV directly on the C-200 would be an great workaround for now.
Besides a work-around, I think a lot of people will find this tool on the C-200 directly very handy.
Hardware of the C-200 is the new Sigma Designs 8643 chipset.
Any info about this is more than welcome :D
Re: MakeMKV for Popcorn Hour C-200
Post by mike admin » Wed Oct 28, 2009 8:44 am
This is the good topic to discuss it. We would need help from someone familiar with development on that platform. The very first question is whether linux on C-200 comes with x-windows system or not. The easiest way to verify feasibility is to compile MakeMKV open-source package and try to execute it on the device. I'm waiting for volunteers to do that. :)
pvdwaal
Post by pvdwaal » Wed Oct 28, 2009 9:36 am
Thanks mike.
Unfortunately I cannot help due my very little (read none) knowledge of Linux and technical/software stuff reguarding the C-200.
But I will ask on the NMT forum.
I would really like to help as beta tester though.
vaidyasr
Post by vaidyasr » Wed Dec 09, 2009 8:19 am
I would like to cross-compile the makemkv. Will makemkv work on command line?
Post by mike admin » Wed Dec 09, 2009 9:00 am
yes, but command-line options are somewhat limited. Please try to recompile open-source part first - libdriveio and libmakemkv and let me know how it goes. Also, please describe why do you need it (what is your usage scenario) - maybe you wouldn't need to run it on the device in a first place.
vaidyasr
Post by vaidyasr » Wed Dec 09, 2009 9:39 am
I was able to compile both libdriveio & libmakemkv without any issues. I am building for mips-linux-gnu which is meant for C200. I am just compiling as most of them request the makemkv software. But personally I don't need it since I don't have the BD source for the makemkv program.
Post by mike admin » Thu Dec 10, 2009 9:33 am
are there any plans to get GUI (x-server) support ?
Please PM me with instructions on how to get a toolchain - I assume that it is standard mipls-linux little-endian buildroot, but what libraries are on device?
vaidyasr
Post by vaidyasr » Fri Dec 11, 2009 7:55 am
rightnow C200 has directfb support. I don't know about x-server support. If there will be a command line, the task can be achieved by using a webserver with php interface to get the input and can process in the player. The toolchain is already available in codesourcery website. The link is http://www.codesourcery.com/sgpp/lite/m ... release824
vaidyasr
Post by vaidyasr » Wed Feb 17, 2010 5:40 am
I have compiled successfully, but while invoke I got a error which says 'Failed to Initialize'. How to fix?
