I have download several Gravity 3D iso and I have the same problem with all of them. When an 'AnyDVD!' folder is in the iso file, an warning will pop up if I open it with MakeMKV directly, so I usually extract the files with poweriso first.
For some reason, poweriso crushes when I tried to extract the files. Then I used Winrar to extract the files, which seems to work fine. However, after I removed the AnyDVD! folder and try to use MakeMKV to make a MKV file of gravity with the MVC codec, it either give an OS error or the ripping process seem to stop and the estimated time needed is very long.
So then I tried to use MakeMKV on the iso files directly, ignoring the warning and to create a 3D file with MVC codec on. It successfully created an MKV. However, I wanted to play the video on my 3D TV and I've find out that directly playing the MKV file in an USB plugged into the TV will only play a 2D video, and that I have to convert the video into a m2ts file in order to get the 3D effects. So then I used tsMuxeR to make the video a m2ts file. I played it with the TV and it seemed to be working, as it play the file with 3D effects on automatically. However, as it finished playing the intro, the video freeze but the audio is still going.
All three iso files I've got had the same result, the videos freeze at the exact same point. Can anyone tell me what did I do wrong?
Problem with Gravity 3D
Re: Problem with Gravity 3D
Hi!
Perhaps the commercial disc doesn't have the same problem as the .iso image files you say you've downloaded...
But I thought the .iso files were created from the commercial discsetarip_old wrote:Hi!
Maybe you should try buying the disc to find out. You know, instead of stealing itBut I thought the .iso files were created from the commercial disc
Stole the video instead of buying it?jerryleung96329 wrote:Can anyone tell me what did I do wrong?
Stole as in the previous owner doesn't have it any more?
Stole as in...
jerryleung96329 wrote:I have download several Gravity 3D iso
I can read but apparently you don't know what "steal" means. Fair enough, the rightsholders don't know either.
Chetwood wrote:Stole as in the previous owner doesn't have it any more?
I know what it means. Does it matter that I'm a linguist? No, what matters is that I can read a dictionary:Chetwood wrote:I can read but apparently you don't know what "steal" means. Fair enough, the rightsholders don't know either.
Oxford Concise:
1. Take (something) without permission or legal right and without intending to return it
2. Give or take surreptitiously or without permission
American Heritage:
1. To take (the property of another) without right or permission
New Oxford American Dictionary:
1. Take (another person's property) without permission or legal right and without intending to return it
Mirriam-Webster:
1: to take the property of another wrongfully and especially as a habitual or regular practice
None require that the property be physical; in fact, three don't even require that the stolen item be property. Also, none require that "the previous owner doesn't have it any more".
As a matter of law one is not charged with theft since taking IP doesn't meet the legal definition, but that does not change the definition in vulgar language and vulgar society. Pirating music, movies, software, etc. is theft—every major dictionary supports this.
- Contact:
As many have indicated, discussions about illegally obtained content are not allowed.
