Failed - Penn & Teller BS season 2
G2pro
#1 Post by G2pro » Thu Feb 11, 2010 8:48 pm
MakeMKV crashes on all the the Peen & Teller BS Season 2 disc. I'm using 1.4.12 on a windows 7 64bit.
I'm running AnyDVD in the background, I've also tried it with out AnyDVD.
Here is the log dump:
Debug log started at Thu Feb 11 20:36:28 2010 , written by MakeMKV v1.4.12 beta win(x64-release)
001005:0000 MakeMKV v1.4.12 beta win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as --------DELETED for privacy----------
003033:0000 Cell 5 was discarded (structure protection?)
001003:0020 DEBUG: Code 1392574465 at jT`~T#\x~GUye:T38*P:121266373
001003:0020 DEBUG: Code 0 at XE^kMHW&[#Z>`<c!]*:29393976
003035:0000 CellWallk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Anyone have this problem or know how to solve it.
thanks
dirio49
Re: Failed - Penn & Teller BS season 2
#2 Post by dirio49 » Fri Feb 12, 2010 5:54 am
is that the full log?
it look like half a log
G2Pro1
#3 Post by G2Pro1 » Wed Feb 17, 2010 3:24 am
Yes, that is the whole log. In fact I cleared the log and did it again to make sure.
I have had no problems with Season 1 or Season 3, but I could never get season 2 to work.
MakeMKV would also crash each time, so maybe that's why the log is short. Don't Know
#4 Post by mike admin » Wed Feb 17, 2010 5:29 am
I would ask you to send IFO files from all 3 discs to support@makemkv.com . Please compress them with archiver of your choice.
