Trying to install Version 1.89
arthur49
Post by arthur49 » Mon Mar 10, 2014 3:28 pm
After downloading and installing 1.89, the program still shows version 1.87
Re: Trying to install Version 1.89
Post by Woodstock » Mon Mar 10, 2014 9:07 pm
Most likely cause is that some part of MakeMKV was still running when you attempted the install, so the old version was not removed. Alternatively, you might not have been installing with administrator privileges, so the old files could not be removed.
Reboot the machine. THEN try the install.
