makemkvcon is not extracting all audio streams
Donny Bahama
#1 Post by Donny Bahama » Fri Feb 28, 2014 2:55 am
I'm working with The Incredible Hulk (2008). If I open it up in Handbrake, it shows me 6 audio tracks- DTS in English, Spanish and French, 2 English AC3 tracks, and 1 English DTS-HD MA track. I run
makemkvcon --minlength=3600 -r --decrypt --directio=true mkv disc:0 all .
and when it's finished and I open up the resulting mkv file in Handbrake and look at the audio tracks, it only gives me the 3 DTS tracks.
Any suggestions on what I might be doing wrong, here?
Re: makemkvcon is not extracting all audio streams
#2 Post by mike admin » Fri Feb 28, 2014 6:40 am
Not all tracks are slected by default - you need to change default selection rule, either in preferences or in profile.
Donny Bahama
#3 Post by Donny Bahama » Fri Feb 28, 2014 5:04 pm
OK, but I'm struggling to use profiles. I posted some questions but no one has responded. I downloaded the "profile1.mmcp.xml" template that was posted in one of the threads, and I modified the selection rule in the default section, but when I try to use it:
makemkvcon --minlength=3600 -r --decrypt --directio=true --profile=/media/rip.tmp/prefer-multi-lossless.xml mkv disc:0 all .
I get the following:
"Profile parsing error: output format invalid","Profile parsing error: %1","output format invalid"
Failed to load profile from file '/media/rip.tmp/prefer-multi-lossless.xml', using default
Donny Bahama
#4 Post by Donny Bahama » Thu Mar 06, 2014 4:19 pm
Through much trial and error, I have gotten beyond this point, so please disregard this thread.
