Throne of Blood
bernard
Throne of Blood
#1 Post by bernard » Sun Mar 02, 2014 12:40 am
The main title won't rip. The two lesser titles rip without trouble.
Here is all it says, which it says immediately, without delay:
Saving 3 titles into directory // ... /Movies/Throne of Blood using profile 'FLAC' from file 'C:\Program Files (x86)\MakeMKV/flac.mmcp.xml'
Failed to save title 0 to file //... /Movies/Throne of Blood/THRONE_OF_BLOOD_t00.mkv
I tried the disc in two different drives, same result.
I've ripped many, many blu-rays without trouble.
Sorry for not knowing how, but is there any error log file that has more info?
Re: Throne of Blood
#2 Post by Woodstock » Sun Mar 02, 2014 3:41 am
Enable debug logging (link in my signature) and post the log from the rip. What you posted doesn't have sufficient information to say anything.
bernard
Re: Throne of Blood
#3 Post by bernard » Sun Mar 02, 2014 4:23 am
Woodstock,
Thank you very much. Here is the debug log:
Debug log started at Sun Mar 02 04:13:56 2014 , written by MakeMKV v1.8.8 win(x64-release)
001005:0000 MakeMKV v1.8.8 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\ ... /MakeMKV_log.txt
005075:0000 The new version 1.8.9 is available for download at http://www.makemkv.com/download
DAFD=PAAAADAAAAEABDQEEEgADAQ==
DCE=+OpiYmLt8iGoMEzFIYaR4YKuRVYDtujaJ8KwGE9NP+GjBBRuSrvhdcS4pJh7p4yb4ODOrHmf974d08Le+Gz4+7MrrMpttB6fwot5Z7byDY9boEUCphFDsOi0BybqXMIdmApUqTHroxTnzp6OXt64onYYvzK/bpM3JA==
DCE=YmJiYmLiw7dxlGf0SWz/hKvbE1Z0pI7mjM75VEK7G67/6M2i09hDH6Mi27Agh4sDLeUr7kjvUp5uT2AniWU+LaEeLmZL1fOLZZBa1p/rG1nsift0kmct3ZBRopv/DY2jNBgInDQWRphioycyiDgn238Cjk5HfT7t5g==
DISCID=7807D688403C89A563AC611563A016F14EE5C935
003307:0000 File 00001.mpls was added as title #0
003025:0000 Title #00021.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00230.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00231.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00295.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00304.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00305.m2ts was added as title #1
003307:0000 File 00306.m2ts was added as title #2
005015:0000 Saving 3 titles into directory // ... /Movies/Throne of Blood using profile 'FLAC' from file 'C:\Program Files (x86)\MakeMKV/flac.mmcp.xml'
005001:0308 File // ... /Movies/Throne of Blood/THRONE_OF_BLOOD_t01.mkv already exist. Do you want to overwrite it?
005001:0308 File // ... /Movies/Throne of Blood/THRONE_OF_BLOOD_t02.mkv already exist. Do you want to overwrite it?
FFENC001: option compression_level=5
001003:0020 DEBUG: Code 402766720 at aU6O@0b|?Id}aL<Q,Sm.:213137160
001003:0020 DEBUG: Code 0 at aU6O@0b|?Id}aL<Q,Sm.:121268972
001003:0020 DEBUG: Code 0 at G&7*7,,i+|8dY=d^4)(yD:213131640
001003:0020 DEBUG: Code 0 at G&7*7,,i+|8dY=d^4)(yD:121265338
001003:0020 DEBUG: Code 0 at !jCxAOitK#1nC? M ;F2:213129616
001003:0020 DEBUG: Code 0 at !jCxAOitK#1nC? M ;F2:213129869
001003:0020 DEBUG: Code 0 at <.S]dGgr|W+j@>#,v*xZH:121262808
001002:0020 LIBMKV_TRACE: Exception: UpdateTrackInfo failed
005003:0000 Failed to save title 0 to file // ... /Movies/Throne of Blood/THRONE_OF_BLOOD_t00.mkv
005002:0000 Title 1 skipped
005002:0000 Title 2 skipped
005004:0080 0 titles saved, 1 failed
Application exited at Sun Mar 02 04:16:37 2014
Re: Throne of Blood
#4 Post by mike admin » Thu Mar 06, 2014 9:27 am
A known bug in 1.8.8 that is fixed in 1.8.9 - please use the latest version.
bernard
Re: Throne of Blood
#5 Post by bernard » Tue Mar 11, 2014 1:10 am
Thank you Mike! It worked.
