1.8.9 Evaluation Expired?
whkana
Post by whkana »
I even did a re-download and re-install, and the expiration date is April 24, 2014, but the program insists that the evaluation has expired?
Anyone who has the correct code? What gives?
Thanks in advance for your help.
AK
Re: 1.8.9 Evaluation Expired?
Make sure your system date is set correctly... I've seen systems where everything looked right, until you checked the YEAR.
whkana
Post by whkana »
I just checked my sys tray, and the clock says March 04, 2014.
kalaxy
Post by kalaxy »
You are probably trying to rip a blu-ray. If you are, see this topic and see if the same resolution works for you.
