The Hunger Games BD, which chapters to choose
Re: The Hunger Games BD, which chapters to choose
Would not be the first time a disk was particular about what played it... Had it happen with a DVD yesterday. No visible flaws, cleaning did not change things, but ripping with a different computer (same model LG BD drive) worked without error. I also have computers with DVD players, because some DVDs show errors with the BD-spec laser, but not with a DVD-spec.
Westyfield2
Just came back to this as I had the disc in my "not ripped pile".Westyfield2 wrote:I've got this Blu-Ray and still haven't worked out which title it is!So should only one of them be 2:22:33 long?
I found the whole rental discussion thing interesting. Ignoring the whole legal issue that's the same with ripping a rental disc as a purchased disc, I guess the morals come down to whether you keep the MKV file after you've sent the disc back (which is bad)... but obviously the same would be true with a purchased disc once you no longer own it (sell it on/exchange) or if you'd borrowed it from a mate.
At the time of my post above, I ripped 00506.mpls (2:22:33, 41.3GB) at random.
Looking through this thread, the following suggestions that have been posted are all NOT present on my disc:
- 00076.mpls
- 00665.mpls
- 00108.mpls
- 00447.mpls
- 00462.mpls
- 00565.mpls
- 00832.mpls
- 00843.mpls
- 00876.mpls
- 00971.mpls
- 00800.mpls
- 00044.mpls
- 00017.mpls - "Correct for Netflix"
On my disc it's 2:24:25 and 41.9 GB.
Segment map: 501,507,6,503,512,505,5,8,506,9,502,509,504,7,508,1 - 00505.mpls - "UK, slightly longer because of frame rate differences"
On my disc it's 2:23:33 and 41.6 GB.
Segment map: 501,507,6,503,512,505,5,506,511,9,509,504,508,1 - 00506.mpls - "Matches the chapter durations shown on my Bluray player"
On my disc it's 2:22:33 and 41.3GB
Segment map: 501,507,503,512,505,5,506,9,509,504,508,1
(This is actually the one that I ripped previously at random)
Does anyone know which is correct? Although I ripped 00506.mpls previously, I don't actually know if it's correct. I'm guessing now the correct one is either 00017/00505/00506/00637
The full listing by MakeMKV is
File 00227.mpls was added as title #0
File 00858.mpls was added as title #1
File 00989.mpls was added as title #2
File 00001.mpls was added as title #3
File 00770.mpls was added as title #4
File 00505.mpls was added as title #5
File 00085.mpls was added as title #6
Title 00152.mpls is equal to title 00858.mpls and was skipped
File 00964.mpls was added as title #7
File 00753.mpls was added as title #8
File 00976.mpls was added as title #9
File 00454.mpls was added as title #10
File 00459.mpls was added as title #11
File 00637.mpls was added as title #12
File 00687.mpls was added as title #13
File 00642.mpls was added as title #14
File 00638.mpls was added as title #15
Title 00769.mpls is equal to title 00687.mpls and was skipped
File 00321.mpls was added as title #16
File 00997.mpls was added as title #17
File 00549.mpls was added as title #18
File 00896.mpls was added as title #19
Title 00337.mpls is equal to title 00227.mpls and was skipped
File 00330.mpls was added as title #20
File 00969.mpls was added as title #21
File 00467.mpls was added as title #22
File 00673.mpls was added as title #23
File 00397.mpls was added as title #24
File 00951.mpls was added as title #25
Title #00003.mpls has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00276.mpls is equal to title 00858.mpls and was skipped
File 00017.mpls was added as title #26
File 00384.mpls was added as title #27
File 00768.mpls was added as title #28
Title 00754.mpls is equal to title 00964.mpls and was skipped
File 00552.mpls was added as title #29
File 00506.mpls was added as title #30
File 00404.mpls was added as title #31
File 00340.mpls was added as title #32
File 00128.mpls was added as title #33
File 00119.mpls was added as title #34
File 00500.mpls was added as title #35
File 00498.mpls was added as title #36
File 00844.mpls was added as title #37
File 00871.mpls was added as title #38
File 00451.mpls was added as title #39
Title 00567.mpls is equal to title 00397.mpls and was skipped
Title 00805.mpls is equal to title 00384.mpls and was skipped
File 00709.mpls was added as title #40
File 00732.mpls was added as title #41
File 00983.mpls was added as title #42
File 00070.mpls was added as title #43
File 00985.mpls was added as title #44
File 00864.mpls was added as title #45
File 00177.mpls was added as title #46
File 00474.mpls was added as title #47
File 00101.mpls was added as title #48
File 00607.mpls was added as title #49
Title #00021.m2ts has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00273.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00275.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00079.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00115.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00702.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00114.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00272.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00274.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped-
tacocat
Long shot to a very old thread, but did you happen to figure out which was correct for Hunger Games? I just bought the pack of all the movies off amazon and haven't found a definite answer for a segment map to choose.Westyfield2 wrote: Wed Dec 03, 2014 5:24 pmJust came back to this as I had the disc in my "not ripped pile".Westyfield2 wrote:I've got this Blu-Ray and still haven't worked out which title it is!So should only one of them be 2:22:33 long?
Looking through this thread, the following suggestions that have been posted are all NOT present on my disc:The following suggestions that have been posted in this thread are present on my disc:
- 00076.mpls
- 00665.mpls
- 00108.mpls
- 00447.mpls
- 00462.mpls
- 00565.mpls
- 00832.mpls
- 00843.mpls
- 00876.mpls
- 00971.mpls
- 00800.mpls
- 00044.mpls
The one that MakeMKV thinks (Primary title) is 00637.mpls (2:25:48, 42.3GB, segment map 501,507,6,503,510,512,3,505,4,5,8,506,511,9,502,509,504,508,1). I don't know what it is that causes MakeMKV to assign that one as (Primary title).
Segment map: 501,507,6,503,512,505,5,8,506,9,502,509,504,7,508,1- 00505.mpls - "UK, slightly longer because of frame rate differences"
Segment map: 501,507,6,503,512,505,5,506,511,9,509,504,508,1- 00506.mpls - "Matches the chapter durations shown on my Bluray player"
The full listing by MakeMKV isCode: Select all
File 00227.mpls was added as title #0 File 00858.mpls was added as title #1 File 00989.mpls was added as title #2 File 00001.mpls was added as title #3 File 00770.mpls was added as title #4 File 00505.mpls was added as title #5 File 00085.mpls was added as title #6 Title 00152.mpls is equal to title 00858.mpls and was skipped File 00964.mpls was added as title #7 File 00753.mpls was added as title #8 File 00976.mpls was added as title #9 File 00454.mpls was added as title #10 File 00459.mpls was added as title #11 File 00637.mpls was added as title #12 File 00687.mpls was added as title #13 File 00642.mpls was added as title #14 File 00638.mpls was added as title #15 Title 00769.mpls is equal to title 00687.mpls and was skipped File 00321.mpls was added as title #16 File 00997.mpls was added as title #17 File 00549.mpls was added as title #18 File 00896.mpls was added as title #19 Title 00337.mpls is equal to title 00227.mpls and was skipped File 00330.mpls was added as title #20 File 00969.mpls was added as title #21 File 00467.mpls was added as title #22 File 00673.mpls was added as title #23 File 00397.mpls was added as title #24 File 00951.mpls was added as title #25 Title #00003.mpls has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped Title 00276.mpls is equal to title 00858.mpls and was skipped File 00017.mpls was added as title #26 File 00384.mpls was added as title #27 File 00768.mpls was added as title #28 Title 00754.mpls is equal to title 00964.mpls and was skipped File 00552.mpls was added as title #29 File 00506.mpls was added as title #30 File 00404.mpls was added as title #31 File 00340.mpls was added as title #32 File 00128.mpls was added as title #33 File 00119.mpls was added as title #34 File 00500.mpls was added as title #35 File 00498.mpls was added as title #36 File 00844.mpls was added as title #37 File 00871.mpls was added as title #38 File 00451.mpls was added as title #39 Title 00567.mpls is equal to title 00397.mpls and was skipped Title 00805.mpls is equal to title 00384.mpls and was skipped File 00709.mpls was added as title #40 File 00732.mpls was added as title #41 File 00983.mpls was added as title #42 File 00070.mpls was added as title #43 File 00985.mpls was added as title #44 File 00864.mpls was added as title #45 File 00177.mpls was added as title #46 File 00474.mpls was added as title #47 File 00101.mpls was added as title #48 File 00607.mpls was added as title #49 Title #00021.m2ts has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped Title #00273.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped Title #00020.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped Title #00032.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped Title #00275.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped Title #00079.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped Title #00081.m2ts has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped Title #00115.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped Title #00702.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped Title #00114.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped Title #00029.m2ts has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped Title #00019.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped Title #00027.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped Title #00272.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped Title #00011.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped Title #00023.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped Title #00274.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Edit: MakeMKV and DVDFab are reporting two completely different answers.
JClisby
5 year bump. Anyone ever figure this out?
Diemaster12
I have a copy of a DVD version in which the playtime is 2:22:33. Makemkv is displaying .mpls 00004, 00007, 00010, 00044, 00076, 00234, 00352, 00526 as potential correct choices. 00076 is the only one that matches the 2:22:33 playtime. I would attempt that mpls.
Diemaster12
I just did 00076 and compared a dozen time stamps to my DVD version and it seems to match perfectly. This BD version is a 2 disc set. Disc 1: Movie Disc 2: Special FeaturesDiemaster12 wrote: Sun Mar 29, 2026 10:05 pmI have a copy of a DVD version in which the playtime is 2:22:33. Makemkv is displaying .mpls 00004, 00007, 00010, 00044, 00076, 00234, 00352, 00526 as potential correct choices. 00076 is the only one that matches the 2:22:33 playtime. I would attempt that mpls.
Hope this is the correct .mpls, Seems like it to me.
