Profile
Colonial
Profile
Post by Colonial »
Hi :) Is there a profile that automatically selects the DTS-HD MA Audio Stream - so you don't need to tick this box when ripping ?
Romansh
Re: Profile
Post by Romansh »
You don't need a profile, just a default selection string (Expert Mode has to be enabled in Options).
http://www.makemkv.com/forum2/viewtopic ... 386#p17399
Colonial
Re: Profile
Post by Colonial »
Thanks. Sounds cool. How would I go about setting these parameters on a linux computer using the terminal (I mean which files would I edit is there a sample config file to look at) ?
Romansh
Re: Profile
Post by Romansh »
settings.conf in MakeMKV data directory.
app_DefaultSelectionString = "-sel:all,+sel:video,-sel:mvcvideo,+sel:(eng*audio),-sel:core,+sel:((eng|fra)*subtitle),-sel:forced"
(note, the above is my selection string and probably doesn't achieve what you want to do - replace it with whatever works for you)
Colonial
Re: Profile
Post by Colonial »
Thanks, thanks and thank you. This is so cool!
