MakeMKV on Windows home server 2011
liamgunslinger
#1 Post by liamgunslinger » Sun Mar 02, 2014 8:30 am
hi
I know it works but my question is... is it ok to install makemkv on WHS2011? i have had it on my server before and had few problems.
issues:
- had problem converting and saving directly onto the flexraid
- started saving to drive with windows installed and had problems and ended up rebuilding windows/server (poss not related to makemkv)
thanks
liam
liamgunslinger
Re: MakeMKV on Windows home server 2011
#2 Post by liamgunslinger » Tue Mar 04, 2014 6:51 am
does anyone use makemkv on WHS2011?
#3 Post by Woodstock » Wed Mar 05, 2014 12:05 am
Windows Home Server is not a particularly popular version of Windows, but it SHOULD work. You will need to make sure that MakeMKV runs with administrator privileges, to be allowed to access the hardware directly.
