The Sweeney - Disc 1 - 1 of 2 Std Def Extras will not rip
redpola
Post by redpola »
Very peculiar. Everything else (like all the tracks) from this three disc set has ripped fine but for one track. The process has write access to the filesystem and there are no other same-name files. The other tracks for this disc ripped fine.
I've tried ripping with WDTV profile and with the Default one. Same story. This particular track is a Standard Def extra, of which there are many in this set (and in fact one other on this disc itself) which all also ripped ok.
Title information
Source file name: 00004.m2ts
Duration: 0:12:11
Segment count: 1
Segment map: 4
File name: title04.mkv
Track information
Type: Video
Codec: Mpeg2
Resolution: 720x576
Aspect ratio: 16:9
Frame rate: 25
Track information
Type: Audio
Language: English
Codec: Dolby Digital
Channels: 2
Channel layout: stereo
Sample rate: 48000
MKV Flags: Default
DEBUG: Code 449 at e+-hX6T0)bC!YP" :j@:29399542
DEBUG: Code 0 at e+-hX6T0)bC!YP" :j@:121262854
DEBUG: Code 0 at e+-hX6T0)bC!YP" :j@:213130674
DEBUG: Code 0 at hqPUB,7hr_`X~hSbzMk:S:29398461
DEBUG: Code 0 at hqPUB,7hr_`X~hSbzMk:S:121267017
DEBUG: Code 0 at ,1ccE,G2dfQhK:Uey%):213130674
DEBUG: Code 0 at ,1ccE,G2dfQhK:Uey%):121264303
DEBUG: Code 0 at ,1ccE,G2dfQhK:Uey%):29395908
DEBUG: Code 0 at ,1ccE,G2dfQhK:Uey%):29397771
DEBUG: Code 0 at C^cm=/QB{U[kWx!7:121262555
DEBUG: Code 0 at hqPUB,7hr_`X~hSbzMk:S:121266810
DEBUG: Code 0 at pF"UE(AK~e~I<=!TL8:121267500
DEBUG: Code 0 at pF"UE(AK~e~I<=!TL8:121267914
Failed to save title 4 to file /Users/neil/Downloads/title04.mkv
(This is my first report of a problem with MakeMKV - I hope I've got all the right information in this report)
redpola
Re: The Sweeney - Disc 1 - 1 of 2 Std Def Extras will not ri
Post by redpola »
In my haste I forgot to add:
Mac OS X 10.9.2, MakeMKV 1.8.9 registered.
Post by mike admin »
Please send the full log (as written by MakeMKV) to support@makemkv.com , as it contains additional information.
