Newbie: MKV/Handbrake M4v unreadable by MAC? Windows m4v??
pgaiduk
#1 Post by pgaiduk » Sun Mar 02, 2014 7:49 pm
Trying to get all my Blurays into my iTunes Library for access by Apple TV.
This is my first try of MakeMKV and bluray with Handbrake so maybe I'm missing something.
I ripped Avatar on a Pioneer BDR-XD04 using MakeMKV.
Then Converted the mkv to m4v using Handbrake.
The resulting m4v proved to be unreadable by any of my Macs.
I also noticed that the Handbrake produced m4v file had the little Parallels dual red bar icon indicating that it is a PC file. ???? (I use Parallels on that machine). I tried the same process on my Mac Mini and no luck there either. I checked the file info and it is indeed a m4v but the default reader shows Windows media player???
I have used Handbrake successfully many times in the past using the same hardware with no problems but this is my first attempt with MakeMKV and Bluray.
What am I missing?
Re: Newbie: MKV/Handbrake M4v unreadable by MAC? Windows m4v
#2 Post by Woodstock » Mon Mar 03, 2014 2:16 am
Really, support for Handbrake questions go to the forums on handbrake.fr...
If you are dealing with BD sources and NOT using a nightly-build version of Handbrake, you must explicitly check the "Large file size" option on Handbrake, or the files will not work anywhere.
Beyond that, you'll need to submit encode logs over on the Handbrake forums, and get their expert advice.
pgaiduk
#3 Post by pgaiduk » Mon Mar 03, 2014 1:23 pm
Well I actually thought I was missing something in MakeMKV since I've used HB successfully many times with the same hardware.
I didn't see it as a HB issue but I've been wrong before.
Smithcraft
#4 Post by Smithcraft » Mon Mar 10, 2014 4:41 am
If your rip file plays with VLC then it's not a problem with MakeMKV.
If the file made with Handbrake doesn't play, then it's a problem with Handbrake and settings you may have used or not used.
SC
